Results 1 to 3 of 3
Thread: Bathroom venting question
Hybrid View
    DIY Junior Member wrea398's Avatar
    Aug 2010
    PA
    Default Bathroom venting question
    Hi guys. I am in the middle of chosing a new vanity for my bathroom. The choices I am down will most certainly make me have to move the sink drain and the (revent) vent line to the left about 8". My question is about vent pipe orientation in relation to the sink drain. The main sink drain goes from the sink, thru the wall and tees right and left. RH goes to the main drain about 4 feet away and also tees up and vents to the roof. LH goes into the revent pipe that goes up the wall cavity about 6 feet and 90s right and goes over to the same vent line that exits the roof. My setup is pictured below. What I want to do is also pictured next to it. Moving the sink make the revent pipe go from LH of the sink drain to RH of the sink drain. Not sure if it will move air the same way. let me know what you think. BTW.... the wall has only been opened up about 24" from the floor to access the drain and water lines. I wanted to leave all vent pipes alone if possible.
    Nov 2010
    Maine
    eeeeeeets sallllllright
    Aug 2010
    PA
    WOW that was fast... Thanks Tom. Just wasn't sure if the revent tube HAD to be before the drain or if it could be after. Thanks again!
  1. Basement bathroom venting question
    By plumbingnewbee in forum Plumbing Forum Discussion & Blog
    Last Post: 04-23-2010, 08:23 AM
  2. Bathroom Venting Question
    By Louie C in forum Plumbing Forum Discussion & Blog
    Last Post: 04-21-2009, 04:29 AM
  3. Question about basement bathroom venting
    By gobble in forum Plumbing Forum Discussion & Blog
    Last Post: 01-19-2008, 09:00 AM
  4. Bathroom exhaust venting question
    By Livin4Real in forum HVAC Heating & Cooling
    Last Post: 09-13-2007, 12:22 PM
  5. Basement bathroom venting question
    By koenigcj10 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-07-2006, 05:36 AM
