Results 1 to 2 of 2
Thread: Low spot in back yard got lower
    DIY Member teve's Avatar
    Aug 2011
    Minnesota
    Default Low spot in back yard got lower
    In the back yard, by the back fence, a roughly 6'x10' area of ground seems to have dropped or settled a few inches. It's next a pole with underground power/phone/cable. There is an ice/water puddle formed there that wasn't there last year. From the grass I can see near the edge it does seem a little more sloped. A portion of the fence is also leaning a bit. I'll be more certain when snow is gone. Everything is working OK, but should I do anything in the spring?
    Feb 2011
    NW Ontario, Canada
    It does sound like settling but could also be frost heaving. Often when a trench is backfilled, it may react differently as the frost is leaving the ground.
    I roll my yard in Spring while the ground is still sopping wet and then plug aerate after it dries up a bit. I then redistribute the plugs, taking them from the high spots and leaving them in the low spots. I also top dress with compost which tends to go on a little thicker in the low spots. After repeating this for about 20 years, the results are noticable.
  1. Need help with drainage in back yard
    By Michael Rudd in forum Irrigation / Sprinkler Forum
    Last Post: 06-21-2011, 08:06 PM
  2. Sewer gas from stack, stinking out back yard
    By burleymike in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-03-2011, 04:43 PM
  3. Toilet Seat For Bad Lower Back
    By Kiko in forum Toilet Forum discussions
    Last Post: 08-28-2010, 01:14 PM
  4. AWFUL SMELL IN THE BACK YARD and it is a tree
    By Dunbar Plumbing in forum Computers and Stuff
    Last Post: 06-15-2009, 09:12 PM
  5. Critters are ripping up my back yard
    By skippertom in forum Lawn Care/Landscaping
    Last Post: 08-02-2006, 06:16 AM
