Results 1 to 6 of 6
Thread: Kohler shower caukless adaptor tricks?
    Default Kohler shower caukless adaptor tricks?
    Spent about 2 hrs trying to install a kohler shower drain. I cannot get the caulkless adaptor piece all the way down. I've soaped everything and just cannot get it installed.
    Any tricks?
    Thanks.
    Tim
    Homeowner
    Jan 2010
    Alabama
    Is the pipe coming up through the drain vertical or is the pipe off to one side not allowing the gasket to slide down? What kinda pipe is it?
    I sometimes split off some wood to the correct size and use it as a blunt chisel to push the rubber seal down. Make sure it's flat on the end so it doesn't split or tear the rubber seal. You can tap the wood tool you made with a hammer.
    Thanks. The PVC pipe was centered, but not perfectly square to the drain. I did use a mallet to get it down. I hope it doesn't leak as I dont want to do that again, ever.
    Tim
    DIY Junior Member curlysir's Avatar
    Sep 2009
    Texas
    I used a carpenter pencil and a plastic headed hammer to install the seal on my drain I installed recently. The pencil was the only thing I had close at hand and it worked. These seals are a real pain in the rear to install. I hope they are good.
    Homeowner
    Jan 2010
    Alabama
    I have a trick to install those on PVC pipe........But it is classified info. Top secret. I MIGHT would share it with Terry since it is his forum.
  1. Vespin II Adaptor Help !
    By FJK in forum Toilet Forum discussions
    Last Post: 09-17-2010, 01:34 PM
  2. Pitless Adaptor
    By eod4647 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-16-2010, 12:29 PM
  3. Which shower arm adaptor
    By md001 in forum Shower & bathtub Forum & Blog
    Last Post: 05-21-2010, 06:54 PM
  4. Kohler lowboy rebuild tips&tricks needed
    By JeffH in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-01-2007, 04:13 AM
  5. rough-in adaptor?
    By cme10ae in forum Toilet Forum discussions
    Last Post: 03-18-2005, 09:33 AM
