Results 1 to 7 of 7
Thread: MOEN Bathtub faucet is leaking....not sure what to do
    DIY Junior Member P0kerMunkee's Avatar
    Mar 2012
    Woodland Park, CO
    Default MOEN Bathtub faucet is leaking....not sure what to do
    Hi,
    I demo'd my main bathroom, but won't have the contractor in for another 2-3 weeks to finish it up.
    My issue is the spout is dripping water, about 20oz in 8hrs. It was leaking before, but now that there is no tub to catch it, it's an issue.
    How do I fix this valve body? It's nothing I have seen in HOW TO videos online. Do I need to have my plumber fix this or is something I can easilly do?
    Thanx
    PM
    Mar 2012
    Woodland Park, CO
    I'm almost 99% certain this is a Moen faucet.
    Is this the cartridge I need?
    Moen 1225B
    Are you planning on reusing that when you rebuild the bathroom, or replacing it? If replacing it (well, it really doesn't matter), I'd go pick up a Sharkbite end cap, clean the pipe up a bit, slide it on and it's capped...doesn't matter if the valve leaks or not! You'd need two, on on the spout outlet and a second on the shower riser since when you plug one, eventually, it would leak out the other opening. You may be able to use a plug on the shower arm. Don't forget some tape or pipe dope on the threaded connection...don't put anything on the Sharkbite.
    If you are going to reuse it, then a new cartridge would probably solve the issue as well.
    Mar 2012
    Woodland Park, CO
    Thanks, that is also what I was thinking.
    Would you guys get a new cartridge or have the plumber install a new valve?
    The house is almost 30 years old. Does it matter?
    A 30-year old valve probably does NOT meet current anti-scald rules, so yes, I'd replace it. You'll likely have a lot more choices on trim as well. Personally, I like a thermostatically controlled valve, but by no means are they required - an anti-scald one, though, is. There are single handle (on/off/volume), two handle (often concentric) for volume and temp, and thermostatic (usually two handles, one for temp and one for volume). on mine, I don't really change the temp dial winter/summer, first shower, last shower.
    You should install a new pressure balanced valve while the wall is out. It's getting harder to find trims for the Moen valve that you have.
    If you do replace the cartridge, get the original Moen replacement.
    A Moen 1225 works.
    http://www.terrylove.com/images/moen1225.gif
    If you replace the cartridge do NOT use anything other than one with the Moen name on it. Especially NOT one labeled "for use in Moen faucets". If you do not want to change the valve, call 1-800-BUYMOEN and have them send you an OEM 1225 cartridge.
  1. Leaking Moen Bathtub valve
    By b2001 in forum Shower & bathtub Forum & Blog
    Last Post: 03-30-2008, 02:38 PM
  2. Leaking Moen Kitchen Faucet
    By bookworm in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-21-2007, 08:19 AM
  3. Leaking Moen Bathtub Spout Diverter
    By SJK in forum Shower & bathtub Forum & Blog
    Last Post: 09-13-2007, 09:46 PM
  4. Moen single control bathtub/shower faucet leak
    By gmrsich in forum Shower & bathtub Forum & Blog
    Last Post: 04-15-2007, 10:13 AM
  5. Bathtub: can't turn water off on Moen Faucet.
    By bnbhoha in forum Shower & bathtub Forum & Blog
    Last Post: 09-21-2005, 09:14 PM
