Thread: [HELP] Installing toto washlet on existing toto aquia II toilet
    DIY Junior Member stone's Avatar
    Mar 2012
    SF
    Exclamation [HELP] Installing toto washlet on existing toto aquia II toilet
    My plumber and I are trying to install a TOTO SW554-01 Washlet S300 on a TOTO CST416M Aquia II Toilet
    It seems to be impossible. Because the Toto Aquia skirt wraps around and hides the connections where the junction valve from the washlet should be. Now we are stuck.
    Is there an extension to connect the junction valve for the washlet to the water supply and goes to the toilet.
    If so, does the junction valve just "hang" only connected to two water supply hoses?
    any tips or help greatly appreciated!
    It's a THU9090 Washlet adapter extension.
    Basically, it's an extension from the tank that allows the tee valve to be out in the open. The tee threads onto the end of the extension, and the supply to the bottom of the tee.
    Mar 2012
    SF
    Fount it! thanks, Terry.
  1. Does a Toto Washlet S300 fit a Kohler Highline toilet?
    By Plumber Wannabee in forum Toilet Forum discussions
    Last Post: 12-05-2011, 03:30 AM
  2. Toto Washlet on Kohler Rialto toilet
    By guch in forum Plumbing Forum Discussion & Blog
    Last Post: 12-12-2010, 12:14 AM
  3. Toto Aquia to washlet feed
    By toolaholic in forum Toilet Forum discussions
    Last Post: 07-14-2010, 09:02 PM
  4. Problem Installing Toto Aquia on Closet Flange on Floor
    By herbolaryo in forum Plumbing Forum Discussion & Blog
    Last Post: 11-20-2007, 08:35 PM
  5. Toto Aquia and Chloe Washlet
    By Johnl in forum Toilet Forum discussions
    Last Post: 01-29-2006, 02:23 PM
