Thread: burner won't stay lit
    DIY Junior Member jfowells's Avatar
    Feb 2012
    Los Angeles, CA
    Default burner won't stay lit
    I have a gas water heater with an odd burner issue. The pilot stays lit, and in fact I'm able to light the pilot without pushing down the pop-up button, even when in the on position. It doesn't seem like the thermocoupler is requiring heat to maintain the pilot. Does this mean the pop-up is defective, and preventing gas from reaching the burner? When the pilot is lit and I turn up the thermostat, there is an immediate rush of gas to the burner, which fires up as it should, but just as quickly dies down to a flicker. The flame from the gas supply to the burner is big and yellow, but the burner itself seems to have a very limited gas supply. Barely a flicker from some of the ports (?), except in the back, where the flame seems stronger.
    Does this sound like a thermocoupler/thermostat problem, or a block in the gas supply in the burner?
    The thermostat is a Robert Shaw Unitrol, 68-184-335.
    The heater itself is an American, installed in 2002.
    thanks
    Folks like you that tinker with their gas appliances in spite of having no understanding of them scare the hell out of me. There are many things we can DIY, but there are some tasks best left to the trained and equipped serviceman. I don't mean to offend you, but do think about the consequences.
    Aug 2009
    Midwest
    It sounds pretty screwed up...to the point that it should be looked at by someone who can fully diagnose it. Most importantly, it doesn't sound like it is operating in a safe condition and needs professional attention: able to light the pilot when it shouldn't, operating with yellow flame (although this might just be due to start up condensation), operating with uneven burner pattern, and having it shut itself off quickly after ignition. With a 10 year old tank there could be any number of problems, so be ready for replacement.
  1. Replies: 6
    Last Post: 10-09-2012, 02:26 PM
  2. shutting down my oil burner
    By deb and jim in forum Boiler Forum
    Last Post: 09-12-2011, 12:46 PM
  3. pilot light and burner won't stay lit longer than 30 seconds
    By renrag in forum Water Heater Forum, Tanks
    Last Post: 09-25-2010, 06:59 PM
  4. Is it possible to have both an oil and gas burner?
    By richb2 in forum Boiler Forum
    Last Post: 01-11-2010, 05:18 PM
  5. Water Won't stay hot-tankless oil burner
    By rstier in forum Plumbing Forum Discussion & Blog
    Last Post: 04-25-2005, 03:42 PM
