Results 1 to 4 of 4
Thread: Toilet flange extender
Hybrid View
    DIY Junior Member dmcarthu@pacbell.net's Avatar
    Nov 2010
    Chelan, WA
    Default Toilet flange extender
    Gents,
    A new tile floor has resulted in a finished surface 3/4 of an inch above the existing 4" cast iron flange which is seated in the concrete slab floor. The inside of the cast iron pipe - where it is level with the flange - is slightly irregular (lead?) and may make it difficult to insert a rubber gasket in to the 4" pipe. I plan on installing a new low flow toilet and would appreciate advice on selecting an extender and gasket.
    dmm
    Jan 2008
    Sioux Chief makes flange extenders in both 1/4 and 7/16 thicknesses, either of which can be stacked to create the desired thickness. The extenders go on top of the existing flange- there is no gasket.
    Besure to seal between the flange and extender(s), and secure the extenders because plastic has a tendency to "warp" over time if it is not firmly anchored.
    Aug 2009
    Midwest
    Yes, and that's in the instructions for the Sioux Chief extenders as well (printed on the ring.) Don't let the big box store former "plumbers" talk you out of this sealing step by telling you, "I never do that."
  1. Do I need a flange extender
    By Dom Z in forum Toilet Forum discussions
    Last Post: 10-10-2009, 11:00 AM
  2. flange extender
    By annoz in forum Toilet Forum discussions
    Last Post: 12-23-2006, 03:41 PM
  3. flange extender??
    By zee in forum Toilet Forum discussions
    Last Post: 06-22-2006, 05:50 AM
  4. flange extender
    By farrington in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-17-2006, 07:21 PM
  5. Toilet Flange Extender Thickness
    By Don Zorn in forum Toilet Forum discussions
    Last Post: 01-10-2005, 06:29 PM
