Results 1 to 2 of 2
Thread: Low Brass Flange
    DIY Junior Member Alex-'s Avatar
    Mar 2012
    Illinois
    Default Low Brass Flange
    Hi,
    I recently redid my bathroom floor due to what I guess was a leaking wax ring. Pulled up nasty particleboard under luan/sheet vinyl that was hiding it all.
    I replaced all of it with a nice tile floor, and (as you've probably guessed) my closet flange is about 1/8" under the new floor level.
    I have what looks like a 4" brass closet flange on a 4" copper waste line. The new plywood subfloor/hardibacker is wedged under it pretty nicely so it shouldn't move.
    I bought Quik-Fix's Close Flange Extender kit from my local Lowes (http://www.quickfix****************.com/prod02.htm).
    Do you know if I can use this on a brass flange or would you recommend another product?
    I tried the email address on their site (delivery failed), and their phone number (nobody picked up), so I'm at a loss for advice.
    Thanks,
    Al
    Jan 2008
    You should have removed the flange and then finished the floor, as the flange should be on top of the tile.
    As long as the extension and flange are flat and can be sealed together properly, it should work.
  1. Brass/Lead Flange Problem
    By dougonbay in forum Toilet Forum discussions
    Last Post: 09-15-2010, 02:39 PM
  2. Raising brass toilet flange
    By TonyD in forum Toilet Forum discussions
    Last Post: 03-22-2010, 06:24 PM
  3. New brass closet flange on lead drain
    By Zach in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-05-2009, 09:14 AM
  4. brass toilet flange
    By canton in forum Toilet Forum discussions
    Last Post: 05-03-2007, 05:18 PM
  5. lead bend and brass flange
    By mh718 in forum Toilet Forum discussions
    Last Post: 04-27-2007, 08:37 AM
