Thread: Water pressure on shower - any way to measure?
    DIY Member pktaske's Avatar
    Dec 2010
    New Jersey
    Default Water pressure on shower - any way to measure?
    My shower is done but I'm not 100% satisfied with the water pressure. I have another bath on the same line and I get decent pressure on that one but only after I drilled through the plastic 'restrictor' ball. I'm wondering if my overall water pressure is sufficient. I'm on well with an above ground shallow jet pump. The water line runs runs all the way across my ~85' ranch in 3/4" copper. That transitions to 1/2" at both bathrooms. Any way I can measure this? Any tips on improving?
    Just a note that the pressure coming out of my iron filter when I'm backwashing it is pretty serious so I think the pump is able to generate enough umph.
    Thanks...Nick
    What is your pump pressure switch setup for? 20/40, 30/50, or higher? You should have a pressure gauge near the pump and possibly around your filter to determine its state of health. Don't confuse pressure with volume. Most showerheads seem to be rated at a minimum of 40#. If it is a single showerhead, 1/2" should be fine. Not all showerheads are created equal! Based on federal codes, it shouldn't use more than 2.5gpm. That's pretty simple to measure.
    Dec 2010
    New Jersey
    30/50+. I think it touches 60 actually.
    Maybe the showerhead just sucks. Like I said, the bathroom on the other side of the wall is pretty powerful. I'll switch them out and see what happens.
    Any idea what makes a powerful showerhead?
    Unless modified, it takes some engineering to make a showerhead feel powerful at the federally mandated flow rates. Then, once designed, it has to be manufactured with care. Not all companies do both, and some may not do either! Some people like really high pressure, some like what appears to be high volume. Different showerheads optimize the flow one way or the other, both is a compromise. It is a very subjective thing.
    If you can easily swap showerheads, that would tell you if the valve is sufficient (almost certainly), or if you have some other mechanical issue restricting flow. As said earlier, flow and pressure are not the same...the lower Mississippi certainly has a lot of flow, but it doens't compare to say Niagra Falls for the pressure at the bottom of them!
    Some people in the pump/well area might suggest a cycle stop valve - this would keep the pressure fairly constant, rather than cycling between the max/min with a conventional control system. I've never owned a house with a well, so have never had to deal with that sort of issue.
  1. Newbie question... how to measure flow rate of a shower?
    By SliderJeff in forum Shower & bathtub Forum & Blog
    Last Post: 07-26-2009, 05:53 AM
  2. How Do I Measure Rough in
    By nmchugh6 in forum Toilet Forum discussions
    Last Post: 10-15-2008, 10:11 PM
  3. How do I measure...
    By Abuela in forum Toilet Forum discussions
    Last Post: 05-07-2008, 10:49 AM
  4. Measure twice, cut once - darn!!
    By thezster in forum Toilet Forum discussions
    Last Post: 07-25-2005, 02:50 PM
  5. How can I measure my water pressure at the toilet?
    By JammyDH in forum Plumbing Forum Discussion & Blog
    Last Post: 04-17-2005, 12:17 AM
