Results 1 to 6 of 6
Thread: Well water level sounder?
    DIY Junior Member JPat's Avatar
    Mar 2012
    Johnsburg, Il
    Default Well water level sounder?
    Does anyone have a recomendation on a good frequency sounder for measuring water levels of well with DROP PIPE INSTALLED?
    I am researching an Eno Scientific 2010 Pro and I cannot find a single review of this product.
    Thanks in advance. Jason
    Moderator valveman's Avatar
    Mar 2006
    The most accurate way is to use an air line. I use 1/4" poly with a pressure gauge and schrader valve on a tee up top.
    CT pump guy Teets's Avatar
    Aug 2007
    Watertown, Connecticut
    We use one of theses and they work very well. 2 nice features are they see past torque guides and arrestors, and that you can use automatic static water level logging for tests more than a few hours or days.
    Feb 2011
    NW Ontario, Canada
    If you make a living testing existing wells I think the $1000 would be worth it but you can buy a lot of 1/4" poly for that much. Mind you, taping 1/4" poly to the downpipe is really only practical when setting a pump.
    Mar 2012
    Johnsburg, Il
    Thanks for the feedback so far...The fact that it can "see" past torque arrestors is amazing, never thought to even ask that. As for the poly lines, we deal with a lot of residential wells that have existing pumps set and need to know their pumping levels for upgrades, water levels newly drilled wells(deep) and in monitoring wells etc. I'll keep checking here for more user feedback.
    Also is anyone using a different sounder for this application that I can research and compair?
    thanks again
    Mar 2012
    Johnsburg, Il
    Well, the owner of my company just bought 2...Ive tried it on our office well and it is simple and accurate. I will keep you all updated as we use them.
  1. Toilet Bowl Water Level Alternates Level and Flush
    By leichte in forum Toilet Forum discussions
    Last Post: 09-06-2010, 10:21 AM
  2. water level in toilet
    By limewater02 in forum Toilet Forum discussions
    Last Post: 09-01-2009, 07:39 PM
  3. Measuring Water Level in Well
    By Pump Man in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-04-2008, 12:17 AM
  4. Eco-Drake water level
    By SamC in forum Toilet Forum discussions
    Last Post: 05-23-2008, 06:37 PM
  5. Water level in toilet
    By francus in forum Toilet Forum discussions
    Last Post: 04-15-2008, 12:29 PM
