Results 1 to 6 of 6
Thread: will low flow toilet work on old septic system?
    DIY Junior Member Ten High's Avatar
    Jan 2011
    Upstate New York
    Default will low flow toilet work on old septic system?
    Theoretical question:
    Have a 1950s (6gallon?) toilet (Crane) on even older septic system. I am wondering if a modern 1.6 gallon toilet will work with this old system. here's the existing setup:
    From upstairs toilet, waste pipe has a vertical drop of about 12 feet to right angle turn , then pipe goes horizontal about another 12 feet to another right angle turn, then a horizontal straight run of almost 30 feet out of the house and continuint straight another 20 feet or so to the concrete septic tank . Its about a 1930ish system.
    Just wondering, if I replaced the old fashioned toilet, if the new modern low flow toilet would have enough water discharge to flush things out to the septic tank ?
    The existing system as is works fine and always has, but eventually want to put in all new bathroom fixtures.
    With that distance it will be fine.
    The toilet does NOT care where its waste is going. If it will work with a 100' line to a city sewer, it will work for a septic tank.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    WHAT THEY SAID !
    BUT BE SURE TO CHECK OUT TERRY LOVES REPORT ON LOW FLOW TOILETS !
    http://www.terrylove.com/
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Jan 2011
    Upstate New York
    Everyone, thank you for the answers. Will check out the modern fixtures knowing this.
    Just keep in mind, low flow toilets are not equal. Do heed the advice on Terry's web site.
  1. Which Low Flow toilet would be best for a septic tank?
    By JC101 in forum Toilet Forum discussions
    Last Post: 05-31-2011, 03:39 PM
  2. Re-locating an Aerobic Septic Tank System or use system as-is?
    By pearlbluevtx in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-08-2010, 09:50 AM
  3. Looking for plumber willing to work on septic tank for a trailer
    By KarinB in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-22-2009, 06:50 AM
  4. Will this drain system work?
    By Nelsmarc in forum Remodel Forum & Blog
    Last Post: 06-19-2009, 10:49 AM
  5. Toilet Advice for low pressure well/septic system
    By toiletrookie in forum Toilet Forum discussions
    Last Post: 07-09-2008, 07:26 PM
