Results 1 to 6 of 6
Thread: Water Heater ATP discharge line - how far off ground outside
    DIY Junior Member fortop's Avatar
    Nov 2007
    Tucson
    Default Water Heater ATP discharge line - how far off ground outside
    I am installing a new gas water heater in a utility closet which will have an ATP discharge line going through an outside wall and terminating in a 90 degree bend and short pipe pointed down toward the ground. How far off the ground should that termination after the 90 be? Seems like I read a min/max limit in UPC somewhere.
    min 6" max12"
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    What he said !
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    DIY Senior Member SteveW's Avatar
    Feb 2005
    Omaha, NE
    What is an "ATP discharge line?"
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Quote Originally Posted by SteveW View Post
    Automatic Temperature and Pressure relief valve discharge line -- I think
    Feb 2005
    Omaha, NE
    Thanks - figured it was in reference to the water heater's temperature/pressure valve but thought maybe this was something new.
  1. Is this a discharge / drain line?
    By MaxPower in forum Plumbing Forum Discussion & Blog
    Last Post: 08-07-2011, 08:04 AM
  2. Gas water heater ground
    By hids2000 in forum Electrical Forum discussion & Blog
    Last Post: 05-21-2010, 05:27 PM
  3. Ground water discharge - could it be used effectively??
    By Stevenc in forum Solar and Geothermal Water Heating Forum
    Last Post: 11-27-2009, 06:17 AM
  4. Water Heater Relief Discharge
    By Plumbcatastrophe in forum Plumbing Forum Discussion & Blog
    Last Post: 02-17-2006, 07:42 PM
  5. Ice maker line from cold line of water heater?
    By ccash in forum Plumbing Forum Discussion & Blog
    Last Post: 10-12-2004, 06:20 AM
