Page 1 of 2 12 LastLast
Results 1 to 15 of 27
Thread: basement floor XPS foam
    DIY Senior Member diyfun's Avatar
    May 2011
    MA
    Default basement floor XPS foam
    My unfinished basement has a 87" ceiling height right now. I don't know I should use 1", 1.5" or 2" XPS foam on the floor? The whole basement floor plan will be 6mil poly + XPS foam + 23/32" T&G plywood + engineered wood floor.
    Jun 2009
    Canada
    Personal preference, how tall are the people who live there?
    Jan 2008
    One thing to consider is that a standard door rough-in is 82-1/2 tall. Additional height will be required to install a standard casing around the opening.
    May 2011
    MA
    5'10" for now.
    DIY Member grahamW's Avatar
    Jan 2012
    Ontario, Canada
    Can I ask the purpose of the poly? If your basement floor is allowing water up from beneath then you're likely going to have issues no matter what you do (IMHO).
    I use ship-lapped, rigid foam insulation and use 2" on the walls and 1" on the floor. Glue to the walls & floor with the correcct adhesive and each seam should be tuck-taped, and spray foam used to fill any gaps around the edges. All rigid foam insulation is mould and mildew resistant and won't hold moisture, even if you have a flood in your basement. You can use mould-resistant drywall as well.
    The goal of insulating in this manner is creating a thermal break between the air inside your basement and the air outside. It will eliminate any air movement behind the walls that could lead to condensation.
    Jun 2009
    Canada
    Quote Originally Posted by grahamW View Post
    Mold only grows on organic materials, concrete, poly, foam, etc. etc. none of them support the growth of mold.
    If your basement floods, having gimmicky drywall wont make a difference.
    May 2011
    MA
    The poly is to reduce moisture vapor from the ground and to prevent small amount of water from ground if any. But it will be bad if water is from inside (water pipe), I think.
    In my case, that poly layer is for moisture only because I have added french drain inside my basement and outside grading has been addressed as well.
    May 2011
    MA
    I plan to attach the drywall at least one inch above from the plywood. That means as long as there is no more than 1" water in my basement, the drywall will be safe. I have floor drain and french drain. I think my basement probably should be good enough.
    Feb 2011
    NW Ontario, Canada
    If you need an interior weeping system, then you probably should have a gap as well. Something like dimpled plastic under the insulation, or skip the insulation and put in DRIcore. Insulation on the floor has little payback.
    http://www.dricore.com/en/eIndex.aspx
    May 2011
    MA
    We only get water in 100yr's storm and at that time the outside surface water was not handled properly. Normally there is no water issue and the sum pump basin is dry all seasons
    Jun 2009
    Canada
    I'm really getting fed up with all of the mis-information going on here...
    Feb 2011
    NW Ontario, Canada
    PFFT! We are talking about a basement below grade were the temps are nothing like a room over the garage. Try some ROLAIDSŪ.
    Feb 2011
    NW Ontario, Canada
    If there really was so much payback, you'd think the DRIcore engineers would be all over it and manufacture a version of their product with an inch or two of XPS sandwiched in it. DRIcore has an R value of 1.7 plus the engineered wood that is going on top of that. I don't know the degree days in the state of MA, but for sure less than ours. Summer cooling costs may even factor in.
    Jun 2009
    Canada
    You need to do some research outside of the Home Depot flyer my friend. The main reason DriCore engineers (you think they actually have engineers?), don't add 2" of XPS is COST...
    It is already over priced and uses OSB instead of proper plywood, they wont sell a single 2'x2' tile if they double their price point again.
    Oh and p.s., the other reason is because someone else already came out with such a product. Again, over priced.
    http://www.ovrx.com/
    I think it is hilarious that you figure it takes a team of engineers to glue 2 building materials together and come up with a marketing scheme.
    I would use Delta FL and plywood any day of the week over DriCore, and I would use XPS and plywood any day of the week over any xps+osb glue together crap.
    Jun 2009
    Canada
    For anyone out there listening LLigetfa also recommends MDF baseboards in basements with dampness issues.
    I'll have to head over to Home Depot and ask the experts there, then report back on whether or not having a cold floor in a finished basement is a good idea.
  1. Basement floor redo
    By cmw in forum Remodel Forum & Blog
    Last Post: 01-27-2010, 12:09 PM
  2. Basement floor
    By idoc4u in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-21-2009, 08:10 AM
  3. How to level a basement floor
    By woog in forum Remodel Forum & Blog
    Last Post: 02-17-2009, 12:00 PM
  4. Basement floor raised????
    By lovec55 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2008, 03:36 PM
  5. Basement floor drains
    By dx in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-04-2005, 03:35 PM
