Results 1 to 5 of 5
Thread: Acrylic Shower Pan Installation (MAAX)
    DIY Junior Member cwindingland's Avatar
    Mar 2012
    Saint Michael, MN
    Default Acrylic Shower Pan Installation (MAAX)
    My wife picked out a new corner shower for our unfinished bathroom downstairs. It will be sitting on a concrete slab. The acrylic shell is fairly thin and has a type of molded styrofoam underneath for support. The installation instructions just say to make sure the surface is flat and screw through the flanges where they meet the wall on the two sides. When I set it in place, it feels fairly solid but I was wondering if it should be set in something like a layer of thinset or concrete resurfacer? Thanks, in advance, for your feedback. I appreciate it.
    Homeowner
    Jan 2010
    Alabama
    I would install it just as the directions direct.
    Feb 2011
    NW Ontario, Canada
    I had one of their low end units that was thin and flimsy. The styrofoam deteriorated and the pan cracked from the flexing. Consider returning it if you still can and get one of their higher end models that are much better built.
    If the pan sits flat to the floor, that is enough
    Something under the pan is only used if the floor is out of level, or there is some rocking.
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by cwindingland View Post
    I would feel better about something biting between the two layers.
    I have found that Grani Rapid bites very well to styrofoam but this is a premium thin-set and on the pricy side.
    If you plan on using a liquid membrane and tile walls you could maybe prime the floor with some of the liquid and use some silicone. ???
    Not sure I would just lay it out with nothing else - regardless of what the instructions state.
    Do you have a link to the install guide?
    JW
  1. Acrylic Shower Pan and Cement Board Installation
    By JesseBrud in forum Shower & bathtub Forum & Blog
    Last Post: 03-29-2009, 02:15 PM
  2. Acrylic Tub Installation
    By as28 in forum Shower & bathtub Forum & Blog
    Last Post: 08-01-2008, 04:34 AM
  3. Acrylic Bathtub Installation Help
    By jomass in forum Shower & bathtub Forum & Blog
    Last Post: 07-08-2008, 11:09 AM
  4. Drain installation in acrylic shower base
    By rjm in forum Shower & bathtub Forum & Blog
    Last Post: 03-30-2007, 12:41 PM
  5. Americast bathtub vs Maax acrylic bathtub
    By Wayne Wilmott in forum Shower & bathtub Forum & Blog
    Last Post: 01-16-2005, 03:37 AM
