Replacing tank on vfd
Greenmonster304
Hampton Bays, NY
The tank for my vfd started to leak so I want to replace it but I am not sure what pressure to charge the new tank to. I wasnt sure if the vfd tanks get charged differently. Thanks in advance for your help.
JPat
Johnsburg, Il
huemannwelldrilling.com
Hmmm. Every VFD we have installed, the manufacturer recommends 70% air pressure to running pressure...Doing the math for you; if your running pressure is 60psi the pre-charge in the tank should be 42psi.
JPat
Johnsburg, Il
Meh, tanks go bad all the time. The rubber that most companies are using is recycled... "Do it yourself" tanks have a high failure rate as well. 5yr warranty on all tanks!!!
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Bladder or diaphragm type tanks only go bad for two reasons. Either they rust through, or the bladder breaks. Most of the busted bladders I see on tanks with a VFD, are from the pump not shutting off when it should, causing the pressure to spike and bust the bladder.
One of the big box stores has a 32 gallon tank with a lifetime warranty. I guess it doesn’t have recycled rubber.
