Results 1 to 9 of 9
Thread: Replacing tank on vfd
    DIY Junior Member greenmonster304's Avatar
    Apr 2011
    Hampton Bays, NY
    Default Replacing tank on vfd
    The tank for my vfd started to leak so I want to replace it but I am not sure what pressure to charge the new tank to. I wasnt sure if the vfd tanks get charged differently. Thanks in advance for your help.
    Moderator valveman's Avatar
    Mar 2006
    The tank precharge is usually about 30% less than the running pressure.
    DIY Junior Member JPat's Avatar
    Mar 2012
    Johnsburg, Il
    Hmmm. Every VFD we have installed, the manufacturer recommends 70% air pressure to running pressure...Doing the math for you; if your running pressure is 60psi the pre-charge in the tank should be 42psi.
    Mar 2006
    Hi JPat. Doing the math I think 70% of, or 30% less than 60 is still the same 42 PSI. The real question is why did the tank go bad?
    Mar 2012
    Johnsburg, Il
    Meh, tanks go bad all the time. The rubber that most companies are using is recycled... "Do it yourself" tanks have a high failure rate as well. 5yr warranty on all tanks!!!
    Mar 2006
    Bladder or diaphragm type tanks only go bad for two reasons. Either they rust through, or the bladder breaks. Most of the busted bladders I see on tanks with a VFD, are from the pump not shutting off when it should, causing the pressure to spike and bust the bladder.
    One of the big box stores has a 32 gallon tank with a lifetime warranty. I guess it doesn’t have recycled rubber.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    "Lifetime warranty"...when it breaks, the life is over!!
    Apr 2011
    Hampton Bays, NY
    The tank rusted out because it was in a pit that was always damp.
    Mar 2006
    Quote Originally Posted by greenmonster304 View Post
    Good to know. These are the kind of installations that can benefit from a fiberglass tank.
    Yeah "lifetime warranty". Can you believe that? I think the company might just change names every few years to get out of warranties.
  1. Replacing well tank question
    By marlboro in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-11-2010, 02:20 PM
  2. Replacing 25yr old captive air tank
    By Not4Love in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-22-2010, 11:16 PM
  3. replacing pressure tank
    By jas2218 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-15-2009, 07:34 PM
  4. Replacing a pressure tank
    By psward in forum Plumbing Forum Discussion & Blog
    Last Post: 04-02-2005, 01:54 PM
  5. Replacing plumbing at well supply tank
    By JON in forum Plumbing Forum Discussion & Blog
    Last Post: 01-11-2005, 02:40 PM
