Results 1 to 7 of 7
Thread: Hot water leaks from tub spout during showers
    DIY Junior Member steve42's Avatar
    Apr 2011
    Alabama
    Default Hot water leaks from tub spout during showers
    We have a Price Pfister 3-handle tub/shower assembly in our front bath that is probably about 15 years old.
    Because we are remodeling the master bathroom, my wife and I have been using this bath along with the kids. We have observed a steady stream of water from the tub spout when the taking showers. I know that this is typically indicative of the washer in the diverter failing. The strange thing is that it seems the water that is leaking is hot, not the same temperature as what is coming from the shower head. Is it possible that the leak is only of hot water, or are we simply feeling it as warmer because it is a contiguous stream and not as spread out as the shower spray?
    Thanks,
    Steve
    The water is closer to the source and not aerated.
    You need to replace the loose washer (950-040) that goes over the stem of the diverter.
    Homeowner
    Jan 2010
    Alabama
    I would use 950-040 for that problem. I believe the 950-050 is the cap gasket.
    Apr 2011
    Alabama
    Quote Originally Posted by Hackney Plumbing
    I would use 950-040 for that problem. I think Terry made a typo. I believe the 950-050 is the cap gasket.
    For the money, I'll buy both to make sure.
    I will check Lowe's and/or Home Depot on the way home. The online vendors want to sell me the parts for under $1.00 with $10 shipping!
    Steve
    I like to buy the stem with washer and the seat for it. Not that the seat is the problem with your situation though. As a plumber, if I don't replace the seat, I may need to come back too soon.
    Apr 2011
    Alabama
    I apologize for delaying on my reply here, but we got busy with all of our remodeling efforts and I actually forgot about this repair (and the subsequent advice) until our kids began complaining about there being no hot water when they showered. They began using our master shower instead until I could buy the part (and take the time) to repair it.
    For future reference for folks who stumble upon this thread, don't go to Lowe's or Home Depot for the parts to repair this problem. The washer 950-040 you actually need to repair this problem is not sold there. I wound up buying a whole new diverter stem.
    Also, apparently the PF stem I have is a short shank version; the new stem was much too long. I just used the washers from the new assembly and rebuilt my old stem. Anyway, it fixed the problem.
    The 950-040 washer can be purchased online a few places, but they will eat you alive on shipping unless you are buying other parts as well. If I had gone to a local professional plumbing supply house, I probably could have saved $10-15 on the repair, but otherwise, I believe this solved our problems.
    Thanks Terry and everyone else... excellent advice as always!
    Steve
    quote; I wound up buying a whole new diverter stem.
    I NEVER repair a diverter, and ALWAYS replace the entire stem. You have the Verve style, but bought the diverter for Classic version. They do not always interchange in the bonnet because there are sometimes a thread pitch difference.
  1. Tub Spout Leaks When Shower In Use
    By DarylD in forum Shower & bathtub Forum & Blog
    Last Post: 02-26-2012, 12:38 PM
  2. Diverter spout leaks when water is off
    By dakota in forum Shower & bathtub Forum & Blog
    Last Post: 09-09-2011, 10:02 PM
  3. tub spout just spins - can't remove and leaks
    By brucewe in forum Shower & bathtub Forum & Blog
    Last Post: 06-30-2010, 09:01 AM
  4. Moen tub spout leaks?
    By daddio in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-12-2010, 03:25 PM
  5. bathtub spout leaks
    By popeye in forum Shower & bathtub Forum & Blog
    Last Post: 12-13-2008, 01:56 PM
