Results 1 to 8 of 8
Thread: The Worst Water?
    In the Trades Plumber111's Avatar
    Feb 2012
    North Carolina
    Default The Worst Water?
    What's the worst water situation you recall treating? Just curious.
    Thanks.
    Dec 2009
    Alaska
    One that was changing about every 6-8 hours.
    Found that the depth of the well and the distance from the bluff put the well in line to pull some of its water from the ocean.
    Feb 2012
    North Carolina
    Quote Originally Posted by Akpsdvan View Post
    Mmmmph. That does sound like a nightmare. Ever changing.
    Dec 2009
    Alaska
    It was no wounder that we (the man that I worked for at the time) could never get the equipment to work ... tried different things and still no joy.
    Out side of that ...
    How does 55ppm Fe, 25grains, 6.0 ph sound?
    Oh and did have one that I called the 30/30.... 30ppm Fe and 30 grains.
    Feb 2012
    North Carolina
    Better off pulling water from the ocean.
    Dec 2009
    Alaska
    But then one has the salt level to deal with.... large RO time.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    About the worst I have ever seen is 132 grains. Ended up putting a 4 cf unit on it.
    Jan 2012
    California
    Not so much a water issue, but application. 550 GPM iron removal, high SDI, no chemical injection allowed. Our pilot testing showed Pyrolox was the right choice with Turbidex pre-filter. Ended up using the aquamatic quad backwashing filter design.
    Worst water, hand dug well, 30 feet deep, in a low lying area where runoff constantly gets into it from cow pastures... I refused to guarantee any equipment or perfomance...
    Ended up with Chlorine injection, contact tank, GAC, nitrate and softener systems, Ozone in storage tank, UV after tank, ro for drinking water with post UV. And a disclaimer that I want nothing to do with the performance and that they should not drink or allow skin contact with the water.
  1. American's worst speed traps...
    By Cookie in forum Health and Wellness Forum
    Last Post: 02-20-2011, 12:10 PM
  2. The Best and Worst Jobs for 2011
    Last Post: 01-08-2011, 06:42 AM
  3. Worst thing you have pulled from Toilet?
    By yngwie_69 in forum Toilet Forum discussions
    Last Post: 05-13-2010, 07:50 PM
  4. The worst I have seen in a long time
    By master plumber mark in forum Plumbing Forum Discussion & Blog
    Last Post: 10-16-2007, 04:11 PM
  5. The worst toilet I have ever installed
    By master plumber mark in forum Toilet Forum discussions
    Last Post: 12-03-2005, 06:31 PM
