Kai
Hi All,
I am recently working on increase my water pressure. I have a well system with a blader tank. I adjust the pressure from 30~50psi to 40~60psi. It works great. I have longer and less frequent runs. The shower at the second floor is great. But I also noticed few problems around the tank.
1. The Tee from the bottom of tank is steel or galvanized steel. Does that work with copper pipe? I have replace one piece 1/2" copper pipe previous plumper stucked into a 3/8" fitting. (I am still amazed how he can do that and last many years.) I found the copper pipe is very thin.
2. What is the inside material of the tank? Steel? Is there any special way for preventing the tank from corrosion?
3. I cut off pressure relief valve some time ago. I am planning to put it back. Can I install it cross the basement, where I can access drain better? Any good place to buy plumping supply? I cannot find pure pressure relief value at HomeDepo.
4. Is there any good switch to shut the watter pump off in the case of flooding? I mean electronically not pneumatically. I think I can build one system with some relay. Is there any company making this?
Kai
Kai
