Page 3 of 3 FirstFirst 123
Results 31 to 45 of 45
Thread: GE Smartsoft model gxsf23z01 issues
  1. #31
    DIY Junior Member creations15's Avatar
    Feb 2012
    Spokane
    So I figured out the #113 plug was upside down. Would this be the issue? I changed it around so we will see what occurs.
  2. #32
    Dec 2009
    Alaska
    One side or the other is not going to matter on that flow control button.
    It is a seal inside the valve that you are going to have to replace.
  3. #33
    Feb 2012
    Spokane
    Is this something that a service technician will have to do or is it something mr. avg joe(me) can do?
  4. #34
    Dec 2009
    Alaska
    Depends on your handy level...
    What items have you taken apart, gotten the parts and put back together in working order?
    What might be an hour for some might be half a day for others.
    There are a number of home owners that do their own rebuilds and then there are others that could but have the tech come and do it because they would rather do other things.
  5. #35
    Feb 2012
    Spokane
    I think I've taken the valve apart in the past. Can't remember. I haven't taken anything apart this go around. Just spoke to a tech. Told me to go buy a new one as GE doesn't make the parts anymore and he'd charge me $125 to come out and tell me that. Thought that was interesting. As I've stated before, I'm pretty handy/technical. Is it the figure 8 gasket the only issue or is it the entire #130 in this manual that needs replacing? http://products.geappliances.com/Mar...=003674144.PDF
  6. #36
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Quote Originally Posted by creations15 View Post
    With the right guidance you can do it.
  7. #37
    Feb 2012
    Spokane
    so are you my guidance counselor? which parts are we talking about here? http://www.partselect.com/ModelFrame...E&Type=&Mark=2
  8. #38
    Nov 2010
    Ocala, Florida
    Item # 130 but you can get it cheaper at http://www.softnerparts.com/c=V50V8N...S35X10005.html
  9. #39
    Feb 2012
    Spokane
    I really appreciate the help. I will check back in when completed.
  10. #40
    Feb 2012
    Spokane
    So just to confirm before I order this set of parts, I ran the entire cycle without stopping and advancing it and prior to drained water down to top of salt, which is maybe filled up in the bottom of the brine tank a foot at most, and just checked the water level after complete cycle and the water level has come up probably a foot to make the float switch trigger, so this is meaning that entire valve gasket kit needs replacing right? Nothing to do with Venturi?
  11. #41
    Nov 2010
    Maine
    Yes, the entire gasket kit.
  12. #42
    Feb 2012
    Spokane
    So I replaced the gasket kit and added more salt, then filled up my bathtub twice to drain hot water tank and regenerated twice. The water looks to be filling correctly now and brining correctly now. I will report my happy wife not having flat hair in a few days
  13. #43
    Dec 2009
    Alaska
    If it is adding water to the salt tank and then removing it and there is less salt,....
    I myself would like to place bets on the GE softener horse to win...
  14. #44
    Feb 2012
    Spokane
    Thanks All for helping me with this. my hair is all fluffy again!! wife is super happy. I appreciate it. Next question. Friend of mine has same water softener seems not to be working. Took off cover and it is cycling through and water seems to be draining down to normal level. Cleaned venturi, water may not be filling brining tank, didn't notice this filling. would this be the same issue in replacing all gaskets? Thanks
  15. #45
    Nov 2010
    Ocala, Florida
    If it's not filling, check the black rubber button (brine flow control) in the center of the venturi assembly. There may be debris caught in it.
  1. Know this AS model?
    By hillcrest in forum Toilet Forum discussions
    Last Post: 08-28-2010, 02:11 PM
  2. DWV Model
    By sctclimbs in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-14-2008, 07:12 PM
  3. dleta model 1700 tub/shower issues
    By edspens in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-14-2007, 08:34 PM
  4. Are there issues witht the Carusoe model?
    By stuntman in forum Toilet Forum discussions
    Last Post: 01-07-2006, 01:42 PM
