Thread: Temperature Control valve
    DIY Junior Member I.M.Ardath's Avatar
    Feb 2012
    British Columbia
    Default Temperature Control valve
    I have a Delta Temperature control Valve on my shower. Installed one year ago. Once intstalled I had to
    replace the 'inner valve" as it was defective. The Hardware store replace the "valve" without charge. Now, and basically since it was new it does not preform as other temperature control valves I have had did. The water temperature does not remain constant from one use to the next. Also, when adjusting the temperature control valve it does not "always" adjust the water temperature. Please advise if there is an adjustment or some change I can make so I don't burn my "tootsey" or scald my "butt". Thanks
    Are we talking a thermostatically controlled valve, or just one with a separate temp and volume control? It does make a difference. Depending on the rough-in valve, Delta has three different types of shower valves: pressure balanced single handle, separate temp and volume pressure balanced, and two knob thermostatically controlled. A properly working thermostatically controlled valve should remain pretty consistent temperature. Either of the other two will vary based on the WH outlet temp and the incoming cold water temp. Maybe a call to Delta would help sort out the problem.
    Plumber jimbo's Avatar
    Please post a photo of the valve and the cartridge.
    Nothing is adjustable. Something may or may not be defective. We need to see what you have.
  1. Gas Hot Water Heater-Temperature control
    By jkcsanchez in forum Water Heater Forum, Tanks
    Last Post: 08-22-2009, 11:30 AM
  2. thermostatic temperature control for bathtub
    By BlackNoir in forum Shower & bathtub Forum & Blog
    Last Post: 04-08-2009, 08:40 AM
  3. Solar Thermal Temperature Control
    By reddeuce in forum Solar and Geothermal Water Heating Forum
    Last Post: 02-23-2009, 04:43 AM
  4. Pressure and temperature valve
    By nolow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-18-2008, 06:35 AM
  5. HELP! Cannot Control Temperature on Shower
    By dsglg in forum Shower & bathtub Forum & Blog
    Last Post: 01-07-2008, 07:28 PM
