Results 1 to 13 of 13
Thread: Tub Spout Leaks When Shower In Use
    DIY Junior Member DarylD's Avatar
    Feb 2012
    Toronto
    Default Tub Spout Leaks When Shower In Use
    When the shower is on there is water also coming from the tub spout. This also reduces the water pressure for the shower. The building is a multi level apartment building. Would appreciate any advice.
    In the Trades Plumber111's Avatar
    Feb 2012
    North Carolina
    Supposed too.
    Homeowner
    Jan 2010
    Alabama
    Quote Originally Posted by DarylD View Post
    How do you divert the water to between the tub and the shower? Is it a handle on the wall in the center or is it a knob/ring on the spout that you pull up or down? Take a picture. How much water are we talkin?
    Plumber111: My spouts must be broke because they do not leak while in shower mode. Delta!
    Feb 2012
    Toronto
    Handle is on wall. Quite a bit of water comes from the tub spout when shower is on.
    Feb 2012
    North Carolina
    Might just need to rebuild the diverter.
    Homeowner
    Jan 2010
    Alabama
    have any idea what brand faucet or the age of it? Name on it anywhere? Take a picture and post it and maybe we can identify it.
    Feb 2012
    North Carolina
    Hackney, I've seem many from many brands that leak some. Even when new.
    I just don't consider some leakage necessarily an immediate rebuild recommendation. Maybe that's what I was trying to get across.
    Now a question where I might learn something. If say...a Delta push button diverter does not leak, how does it release after turning the valve off?
    Thanks.
    Feb 2012
    Toronto
    Age of building is 12 years which is when all the fittings were installed. I think it is a Delta, same as kitchen fittings. Can't see any name.
    Homeowner
    Jan 2010
    Alabama
    Quote Originally Posted by Plumber111 View Post
    Thanks.
    I guess all diverter spouts are not equal. I have Delta spouts that you pull the end of the spout down and that activates the shower. They do not leak. The push button diverter is suppose to reset when the water is turned off. It has a spring in it that pops itself back out once you turn the water off. It may have a drip but it should never be a stream. My delta spouts with the integral diverter do not leak any water.
    Same for a kitchen faucet with side spray. When you push the spray button it should shut ALL the water off to the spout. It shouldn't even drip under normal water pressure.....if its on the high side it can drip a bit but never should be a stream.
    Feb 2012
    North Carolina
    Quote Originally Posted by Hackney plumbing View Post
    I guess all diverter spouts are not equal. I have Dleta spouts that you pull the end of the spout down and that activates the shower. They do not leak. The push button diverter is suppose to reset when the water is turned off. It has a spring in it that pops itself back out once you turn the water off. It may have a drip but it should never be a stream. My delta spouts with the integral diverter do not leak any water.
    Thanks. Understood.
    Homeowner
    Jan 2010
    Alabama
    Keep in mind also its not like plumbing spouts are anywhere near perfect pieces of precision made products.......most of them are junk. I get what your saying about some of them leak and I agree they do. Its not a requirement tho and it is totally wasted water. I just had a service call where it leaked so much it was making the water pool up around the person feet because it hit the drain perfect and the shower had a high flow rate. 6 gpm.
    Plumber jimbo's Avatar
    Supposed too.
    I can't really support that statement! If he said he had drips coming from spout...that is one thing. But he has enough leakage that pressure to shower head is low. The diverter mechanism, be it onboard the shower valve, or on the spout, appears to be defective.
    Many diverter spouts are "supposed" to drip so they can reset before the next shower. Spring loaded ones such as the Delta and Moen internal diverters or Delta's pull down diverter will reset against the pressure so they can seal tightly.
  1. Diverter spout leaks when water is off
    By dakota in forum Shower & bathtub Forum & Blog
    Last Post: 09-09-2011, 10:02 PM
  2. Moen tub spout leaks?
    By daddio in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-12-2010, 03:25 PM
  3. bathtub spout leaks
    By popeye in forum Shower & bathtub Forum & Blog
    Last Post: 12-13-2008, 01:56 PM
  4. Kohler Tub Spout Shower Diverter Leaks
    By OhGeorge in forum Shower & bathtub Forum & Blog
    Last Post: 11-30-2008, 02:17 PM
  5. Shower Head/Spout Leaks after remodel
    By rjboykin in forum Shower & bathtub Forum & Blog
    Last Post: 08-20-2008, 03:43 PM
