Thread: Installing washing machine drain in basement apartment, venting/stack Question
    DIY Junior Member ShaneB's Avatar
    Feb 2012
    Ontario Canada
    Default Installing washing machine drain in basement apartment, venting/stack Question
    I have a question about modifying a current copper soil stack/vent to add a washing machine drain in a basement apartment that I will be renting shortly.
    The current plumbing setup behind the basement washroom looks like this:
    Can I cut a section of the copper stack out, replace with PVC, raise the current vent to above flood level of the bathroom fixtures behind the wall, and use a sanitary tee to a trap etc. just about where the current 45 comes off of the main stack for the breather?
    New proposed plumbing:
    Jan 2008
    It is not clear to me what you are trying to accomplish. A horizontal vent needs to be above the flood rim of the highest fixture served, but your drawings show a vertical vent.
    We would need to know what size and type of fittings are being used to determine if if what you intend to do is right or not.
    In most of the U.S., you would be required to be a licensed plumber to perform this type of work in a structure that you do not own. I don't what happens north of the border.
    Jun 2009
    Canada
    If you have a vertical vent stack, why are you tying into the copper stack with your vent?
  1. Washing Machine Stand Pipe/Drop In Sink DWV stack question.
    By kittyarc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-10-2012, 04:51 AM
  2. Basement Laundry Tub & Washing Machine question
    By Ched in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-27-2010, 12:51 PM
  3. Basement Ejector Pump Venting for Washing Machine
    By dbgreg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-11-2009, 05:38 PM
  4. Washing Machine 1 1/2" drain stack?
    By the_slowpoke in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-17-2008, 07:31 AM
  5. Vent stack question - washing machine
    By awilliams in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-13-2006, 07:16 AM
