Results 1 to 15 of 15
Thread: Water Heater In-Line Pump
Hybrid View
    Default Water Heater In-Line Pump
    Hello All,
    Do you guys know of a pump that can be hooked up to the drain of a hot water tank to pump the water out of a basement with no floor drain?
    Tom
    In the trades Dana's Avatar
    Jan 2009
    http://www.amazon.com/Little-Giant-555507-Water-Transfer/dp/B0057PCGA0
    Any water-transfer utility pump that takes standard hose fittings should do ya, but be sure to open some taps to allow air to enter before turning it on.
    Dana,
    Thanks for the link. Now that I know the name of the pump I can do some research and find one. That one doesn't look to bad.
    Are these kinds of pumps affected by hot water coming out of the tank?
    If so how long would I have to let the tank sit idle before pumping it out?
    Tom
    Jan 2009
    You may have to dig up & read the fine print on the pump specs, but I'd be surprised if their operating temperature range crapped out anywhere near as low as 120-140F DHW temps.
    I found this guy. He's made in America. I'm going to buy this one. Anyone object to the quality of this unit?
    http://www.amazon.com/Liberty-Pumps-...=3GSYO6HNMHB19
    Tom
    Dec 2009
    northfork, california
    http://www.bing.com/search?q=zoeller...16&sp=2&sk=AS1
    I object completely, because you'll plug and ruin the pump with the crud that comes out of the drain. You ALREADY have a wet vac, or get one for 39 bucks at true value. Drain into your turkey pan and suck it up.
    Your chosen pump is made for 100 foot of head... as the one reviewer mentioned, he hears the plastic impeller busting up the calcium - he'll soon discover that the impeller is busting up just as much. Its a great pump- but NOT for pumping debri, no matter what the MFG says. The Zoeller uses a vortex action that allows it to pump without disturbing the impeller at all. and the head is about 20'. I recall.
    Then if you want to continue, duct tape a garden hose on the vacuum, and rod out the inside of the tank. you will be shocked at the TONS of crap you will find. THEN turn the inlet cold on a bit and continue, flushing it properly.
    And THEN if you tire of carrying water, get a 9$ drill attached pump with rubber vanes that will pass the small crud.
    Hell, for 139$ you can get a USA Zoeller m53 sump pump and set that in your pan, and it passes huge solids. And you can resell it anywhere. OR you can use it to drain your flooded basement after the flood.
    Be sure to get rid of that joke plastic drain valve and do this thru the hole, replace with a ball valve or plug.
    Dana, I use your rubber impeller pump to move wine around, it will absolutely be plugged in a moment. Even with wine, a seed plugs it and I have to wrap the inlet with Stainless or copper scrubber pads. Even the 9$ drill pump will need you to settle out the solids or filter the pick up.
    Also see that your chosen pump is a brush motor - 5 to 10,000 rpm - CA-CA! the Zoeller really is US made and is a real motor.
    http://www.inspectapedia.com/plumbin..._Procedure.htm
  1. Water Heater gas line
    By pilotboat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-21-2006, 06:31 PM
  2. Hot water recirc line w/ instant water heater?
    By ffmedic7 in forum Tankless Water Heater Forum
    Last Post: 09-04-2006, 02:31 PM
  3. Hot water recirc line w/ instant water heater?
    By ffmedic7 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  4. Hot water heater in/out line sizes
    By jjvanb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-19-2006, 05:37 PM
  5. Ice maker line from cold line of water heater?
    By ccash in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-12-2004, 06:20 AM
