Thread: How to dismantle 1997 rjs-50 red lion jet pump.
    DIY Junior Member rustyIdaho's Avatar
    Feb 2012
    Idaho
    Default How to dismantle 1997 rjs-50 red lion jet pump.
    I want to repair our cast iron rjs-50 red lion shallow well jet pump. Serial no. 2597, meaning 25th week of 1997 I learned. Motor would run but it doesn't deliver or move prime water.
    I took off the four bolts and with a fair bit of pulling split the motor from the pump casing. Now, however, I can't figure out how to get into the casing to check impeller. Apparently the shaft was at least partly unscrewed already, and this allowed me to pull casing / impeller compartment from the motor. But I can't figure out how to open the seal plate -- seems tightly pressed without any entry mechanism. I'll attach photos.
Size:  48.8 KBName:  P1010632.jpg
    Moderator valveman's Avatar
    Mar 2006
    Sorry, I thought someone with one of these might help. Looks like just the seal plate is stuck. If you can get in from the suction side, you should be able to knock it out the back.
    Feb 2012
    Idaho
    Thanks. Yep, just was stuck. Whacking it no good, but an old knife along the gasket and a hammer pried it off. It was difficult to tell there was a seam there.
    For reference, Red Lion parts seem very hard to find, but D&B supply in Idaho carries impellers and rebuild kits in their Caldwell store. And they were very helpful.
  1. burn chamber interior cover for 1997 53 gallon Craftmaster hot water heater
    By homeseller in forum Water Heater Forum, Tanks
    Last Post: 04-24-2011, 08:01 AM
  2. locating back up sump pump in brackish water, minimizing rusting of pump
    By philip o'dowd in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-16-2011, 11:05 PM
  3. 1997 Am. Std. Lexington (2037) one piece 1.6 gal/slush
    By Alan Muller in forum Toilet Forum discussions
    Last Post: 05-17-2010, 11:06 AM
  4. Red Lion Shallow well pump Problem?
    By mhenry in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-18-2009, 12:59 PM
  5. Old 1997 Toto
    By printman518 in forum Toilet Forum discussions
    Last Post: 03-30-2005, 02:18 PM
