Results 1 to 11 of 11
Thread: Toto Supreme II
    DIY Junior Member MarkII's Avatar
    Dec 2012
    California
    Default Toto Supreme II
    I am looking for a new toilet. Based on the info online, it seems like Toto is the way to go. I went to a store and I was looking at the Supreme II.
    Is there any difference in the other one-piece 1.28 gallon toilets like the Ultramax II? Is the flushing mechanism the same?
    It's the same, but different height on the tank.
    Dec 2012
    California
    so it is just a preference in terms of wanting a higher or lower tank?
    Dec 2012
    California
    Would I be better off trying to find an 1.6 toilet or in terms of flushing strength are the new 1.28 Totos just as good?
    Pretty much! Same parts, same trapway and bowl design.
    The 1.28 works fine. I'm selling a ton of them.
    Dec 2012
    California
    thanks so much!
    Dec 2012
    California
    do any of these Toto toilets have extra water in the water tank such that if you hold the handle down you would get more water? Somebody told me some have extra water in the tank that does not give you any more water per flush, but increases the force of the flush. Are either of these true? If so, which models?
    Nearly all modern toilets rely on 'extra' water in the tank to provide the pressure to flush properly (think water tank tower). The higher the tank and the higher the water level, the more pressure. There's a slight difference between toilets based on how high the tank is. Once you get a well-designed, modern toilet, you'll be amazed at how well it works with the design amount - more is just not needed 99.9% of the time. There are some not so well designed toilets out there, but you should be happy with any Toto you might choose.
    Dec 2012
    California
    so with the higher tank of the Ultramax, would I be gaining any more pressure?
    On a different note, I am pretty short (5'3"). I see the toilets as being ADA compliant. Would they be too high for a short person?
    Yakima WA
    The difference in pressure is overrated. Every model Toto makes performs well. ADA compliant toilets are about the same height as a ordinary dining table chair, so you can use that as a guide.
    My mother is 95 and 5'-4"
    After her knee replacement, we installed the taller bowls. She prefers that height now.
    I've also seen small lifts that set by a bowl, in case someone wants to lift the knees higher.
    Otherwise, they do make some standard height bowls, like the MS854114E & MS854114EG Ultramax and the CST744E Drake.
  1. Toilet comparison: Toto Carolina vs. Toto Supreme
    By Ami in forum Toilet Forum discussions
    Last Post: 11-29-2011, 01:08 PM
  2. Toto Supreme ADA
    By Bellcrest in forum Toilet Forum discussions
    Last Post: 08-10-2009, 10:06 AM
  3. TOTO SUPREME anyone?
    By Rob223 in forum Toilet Forum discussions
    Last Post: 04-30-2008, 11:03 AM
  4. TOTO Supreme
    By cwtx in forum Toilet Forum discussions
    Last Post: 04-16-2007, 07:54 PM
  5. Toto Supreme, is it
    By tameria11 in forum Toilet Forum discussions
    Last Post: 12-16-2004, 10:59 AM
