Results 1 to 8 of 8
Thread: kitchen sink mystery leaking
    DIY Junior Member rolliep69's Avatar
    Feb 2012
    las vegas
    Angry kitchen sink mystery leaking
    well, my problem started about 2 month ago. one night i went to the kitchen to find water all over the floor coming from under the kitchen sink. the water was really really steadily pouring out from both the p-trap area and the other sink with the disposal in it. i shut the water valve off and cleaned up the water and went to bed. the next day i turned the water back on to see if i could find the leak but nothing was leaking. so all was well until about a month later when the same thing happened. this time i turned the water back on right after i cleaned up all the water and it had stopped leaking.... then tonight it did it again so i did the same thing and again, no leaking. this happens all of a sudden, it's been hours since any water has been run in those sinks. it just seems to start for no reason but stops when i turn the water valve off under the sink and back on again... what is happening???
    DIY Member Hotbacon's Avatar
    May 2011
    Shillington, PA
    If the leak is coming from the p-trap, turning your supplies off will not stop the leak from occurring. The supplies provide water to the faucet. So, if you turn the supplies off, the leak would continue coming out of the trap until the water in the trap has drained to below the hole/exit point.
    I'm no pro, but try putting a bucket under the trap and turn the faucet on, and allow the water to run. This will ensure the trap is full of water so you can see what's going on. Wiggle the trap around with the water running and see if you see any leaks.
    Plumber jimbo's Avatar
    This is a case where you have to get on your back, wiggle your shoulders inside the cabinet, and start inspecting with a flashlight and feeling everything with your hands. Look for something which is wet!
    DIY Junior Member paulwarren's Avatar
    Feb 2012
    California
    If the faucet is on a flexible tube that extends out from its housing, check that its connection isnt leaking. When you shut the water off and on you may also be fiddling around with the faucet, reseating it in a position that doesnt leak, but after some casual use it might open up again.
    To quote a couple of frequent posters...don't ask me how I know.
    Default leak
    You may have something, such as a water softener drain, connected to your sink's drain and when it regenerates it overflows, or leaks under the sink, for some reason.
    Homeowner
    Jan 2010
    Alabama
    How about the dishwasher? Was it running anytime befo you found the water?
    Feb 2012
    las vegas
    the dishwasher was ran about 12 hours before, and there is a reverse osmosis system hooked up (professionally) under the sink. this is no small leak. i'm talking about 2 gallons a minute leaking out until i shut the water off. then when i turn it back on... the leak has stopped.
    DIY Junior Member 6t7gto's Avatar
    Jan 2010
    Bedford, Ohio
    I would put a pressure gauge somewhere on my water lines.
    I bet the pressure is climbing and causing the leak.
  1. Upstairs Kitchen sink draining into basement kitchen sink
    By DIYRENO in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-18-2012, 05:14 AM
  2. Kitchen sink leaking to outside wall
    By Fisherman in forum Drain Cleaning
    Last Post: 05-17-2009, 05:51 PM
  3. MYSTERY PART - and it's LEAKING - please tell me what this is
    By amateur_plumber in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-05-2009, 01:49 PM
  4. Moen Kitchen Faucet Leaking on 3 Hole Sink
    By kornbln in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2008, 04:01 AM
  5. Leaking kitchen sink vent
    By Carmenbinns in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-29-2008, 01:24 PM
