Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 46
Thread: 14/3 strange usage
  1. #31
    I have heard, but do not know if it is fact, that homes in Australia only have a single 240 volt wire coming into the houses. The return to the generator is done with a "ground connection" into the earth.
    Power HAS TO return to where it came from. The earth is a really really lousy conductor. Sticking a ground rod outside your house will not allow the power to travel through the earth to another ground rod at the power plant. The ground rod is there for protection in the event of a lightening strike.
    -rick
  2. #32
    Mar 2011
    Long Island, NY
    That is simply "shocking" LOL. Drick is correct, there must be something missing in what you heard that provides the return; guess I'll have to Google it.
  3. #33
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    It's called Single Wire Earth Return http://en.wikipedia.org/wiki/SWER
    Last edited by ActionDave; 04-01-2012 at 07:14 PM. Reason: couldn't post differnt link
  4. #34
    Quote Originally Posted by ActionDave View Post
    Heh, well I guess that shows you what I know. I'd never heard of it before now. Thanks for the link.
    -rick
  5. #35
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by drick View Post
    -rick
    "A good earth connection is normally a 6 m stake of copper-clad steel driven vertically into the ground"
    6 meters is about 20'. Imagine trying to drive that damned thing in with a sledge?
  6. #36
    Mar 2011
    Long Island, NY
    Yes, but most of that if not all, is used for medium or high voltage power grid or transmission lines over long distances. In the US, the grid is multiphase, with transformers used for the user's voltages and neutrals that are tapped off the transformer and grounded locally. The ground itself here, at least does not carry any power. I would not my house powered with a single phase and returned to ground though a lake, nor would I want 220v receptacles in my house for our normal plug in appliances. This conversation is still shocking, but interesting.
    Thanks Dave for that info.
  7. #37
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by BobL43 View Post
    nor would I want 220v receptacles in my house for our normal plug in appliances. .
    Yet it is common. It certainly reduces on the cost of the copper to wire a home.
  8. #38
    Feb 2009
    Colorado
    I built my house using steel studs just so I could use a one wire system.
  9. #39
    Jan 2012
    Los Angeles, CA USA
    Zip, zap, pow!
    In the abstract, I suppose you could treat the whole frame of the house as the ground system.....
  10. #40
    Mar 2011
    Long Island, NY
    I don't see any smiley faces Dave!
  11. #41
    Mar 2011
    Houston, TX
    Earth is a good Ground if the voltage is high enough, and that proves it.
    The Power Utility company is the only one allowed to use the earth as ground/neutral, as far as I know.
  12. #42
    Mar 2011
    Long Island, NY
    Oh and Samuel Morse did too, right?
  13. #43
    Mar 2011
    Houston, TX
    That was before AC was used.
    DC was tried before they figured out AC was better for transmitting.
    Later Morse used RF, so it was AC. Just not 60hz, Subs used that frequency.
  14. #44
    Feb 2009
    Colorado
    I rarely smile. The last time I remember feeling one come upon my face was about eight years ago when I was informed of my mother-in-law passing.
  15. #45
    Mar 2011
    Long Island, NY
    Those Colorado Winters didn't give you that cold heart did it? Just kidding (or am I?). I guess I was lucky, I had a great Mother In-Law. If everybody had a Mother In-law like I had, there'd be no mother in-law jokes. That'd be no fun though
  1. spike in ng usage
    By trw888 in forum Water Heater Forum, Tanks
    Last Post: 11-19-2009, 08:58 PM
  2. Pump Usage
    By sapruitt in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-09-2008, 03:42 PM
  3. well usage
    By rbig in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-16-2008, 04:45 PM
  4. How to reduce my KWH usage?
    By ffmedic7 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-29-2006, 10:58 AM
  5. Greywater usage
    By citykid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-29-2006, 03:32 PM
