Results 1 to 3 of 3
Thread: Wire size
    DIY Junior Member MrBillyd's Avatar
    Feb 2012
    Scottsdale
    Default Wire size
    My house was built in 79. I am removing my 30 year old stove/double oven combo.
    The wire that is being fed from the 50amp breaker is about 80 feet long.
    The markings say Stabiloy Type SE XHHW 300volts to ground 3CDRS 6 AL
    My new situation will be an Induction Cooktop on one breaker and seperate double oven.
    The cook top takes a 50amp breaker and the double oven takes a 40amp breaker (per the spec sheets)
    I am pulling another feed which will be 6/2
    Which wire should I put on my 40amp breaker?
    My 30 some year old AL wire has been on the 50amp circuit without issue.
    If the 6/2 could handle the load on the Induction cook top better, then I would swap them
    Bill
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    6 SE AL is only rated for 40A.
    Often double ovens are not straight 240V and would need three conductor plus a ground. Are you sure 6/2 will work for the oven?
    It is probably 6/2 entrance cable which, in the old days, used the outer wrapping for the neutral and ground. Both the oven and cooktop need a 120/240 circuit because of the control wiring. Good call going with induction cooktop. For a long time reasonably priced and available ones were nonexistent. Fortunately, my original one lasted long enough for new 36" models to become available.
  1. Ground wire size
    By Giles in forum Electrical Forum discussion & Blog
    Last Post: 02-17-2011, 11:41 AM
  2. breaker size for 12 gauge wire
    By whoazone in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2008, 05:02 PM
  3. Wire size question
    By jparrie in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2008, 04:46 PM
  4. Intermixing wire size
    By Mr_Magoo in forum Electrical Forum discussion & Blog
    Last Post: 08-13-2008, 03:17 PM
  5. Wire Size / Fixture Attachment
    By OscarG in forum Electrical Forum discussion & Blog
    Last Post: 08-21-2007, 01:48 PM
