Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Thread: Power vent water heater question
  1. #16
    In the Trades Plumber111's Avatar
    Feb 2012
    North Carolina
    Pay close attention to how to calculate the distance...it's not just the straight, you have to subtract some for each change of direction as well. Then, the horizontal sections need to be sloped like a drain because, often, there will be some condensation and it needs to drain outside rather than back to the WH. On things like mod/con boilers, it slopes the other way, but then they also have a trap and a means to dispose of the condensate which doesn't exist on the WH, or at least those I know of (doesn't mean they don't exist).
  3. #18
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Smell is not your problem when venting close to windows or other openings
    carbon monoxide is that is why the distance
    even if windows are closed gas can still leak into the house !
    Carbon monoxide is odorless,invisible, that is why it is called the silent killer !
    http://www.wvmetronews.com/news.cfm?...&storyid=51094
    Last edited by MACPLUMB 777; 02-22-2012 at 01:12 PM. Reason: ADDED LINK FOR LATEST CM
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
  4. #19
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    12" is all that was required for my power vent water heater and my furnace from a window.
  5. #20
    Jun 2010
    USA
    that post has little to do with a residence...
  6. #21
    In searching around BW's website, they have both direct vent and POWERED direct vent systems. Here's one of them http://www.bradfordwhite.com/images/...-47936-00C.pdf, and depending on the size of the piping you use, you could have up to 95' (when you use 4", it's 55' if you use 3" pvc) if you can get by with only one elbow...that should be enough for nearly any house.
  7. #22
    DIY Junior Member B&H's Avatar
    Feb 2012
    Central NY
    On BW's site, they claim about 104" from the centerline of the exhaust pipe on top of the tank, to the outside wall surface. This is on their direct vent 40 gallon tank in my link on page 1, with their standard size vent pipe and no turns. Unfortunately I need to go 120". I see that they advise to call for a different pipe size maybe, for longer distances.
    Judging by what I've read on this site, it would be better to use a direct vent vs a power vent, so maybe it's time to call BW and then a plumber.
  8. #23
    Feb 2012
    North Carolina
    That's sounds like a good plan. I typically discourage Power Vents/Power Direct Vents and try to make others work instead.
    Now to throw a monkey wrench in it all, have you considered an 80 gallon electric as well? Might find it does what you need and costs have changed in many areas where electric can be just as economical. Then no vents, fuel piping, holes in the wall etc.
    But get a CO detector anyway.
  9. #24
    Homeowner
    Jan 2010
    Alabama
    I like an electric water heater. Very simple and easy to get parts. No vent and no gas. Unless you use ALOT of hot water cost of the electricity is not an issue.. The cost of the appliance is cheaper and so is the installation. New codes get thrown at gas appliances all the time while electric heaters are being made the same for years. I have a 12 yr old 50 gal rheem electric that have the original bottom element but I did change the top one after Hurricane katrina. I converted my heater to 110v for a generator to heta me some water,so I used a 1500w 110 element and direct wired it to the element. After an hr or so I would have some really hot water.
    Summary.....I like electric heaters for a warm climate especially.
  10. #25
    Feb 2012
    Central NY
    When we bought this house 20 years ago, we had no gas, so we had an electric 40 gallon tank. 2 years after we moved in, we converted to NG and installed a gas WH. The savings from only switching from an electric to gas WH was significant!
    Fast forward to today, we are a family of 3 and certainly don't use a lot of hot water. Our son is 16, so in a couple of more years we will be empty nesters. I wouldn't know how to calculate the cost of heating water using gas or electricity. Help! We have a NG whole house back-up generator, so power outages aren't a problem. Going back to an electric WH could be a nifty solution!
  11. #26
    Homeowner
    Jan 2010
    Alabama
    Quote Originally Posted by B&H View Post
    Any big tubs to fill? Washing clothes in hot water? You would need to know the cost of your electricity per kilowatt.. It's probably on your power bill.
  12. #27
    Feb 2012
    Central NY
    At our current rates, it would cost about 2.5x to heat with electricity than NG. Yikes, no thanks! So with the guidance of those here, I decided to "rearrrange" the area that the water heater is in (move the new unit closer to the exterior wall) so as to be able to use a direct vent instead of a power vent. New water heater is in my basement (40 gallon Bradford-White) and the longest vent kit had to be ordered directly from the manufacturer. In the short term, a power vent would have been easier to install, but I think the simplicity of a direct-vent made moving a wall the better choice for the long haul. Thanks!
  1. Power vent water heater?
    By topshot in forum Water Heater Forum, Tanks
    Last Post: 10-23-2008, 01:53 PM
  2. Power vent water heater?
    By topshot in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  3. Ruud power vent water heater
    By Peevee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-08-2008, 06:17 PM
  4. Power vent water heater required?
    By rick.a in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-11-2007, 05:25 PM
  5. Power Vent Hot Water Heater Smell
    By wauslh in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-28-2006, 04:17 PM
