Thread: Pentair Freshpoint water filter
    DIY Junior Member jetdad's Avatar
    Feb 2012
    texas
    Default Pentair Freshpoint water filter
    I had a new well drilled 2 months ago and can't get the water to clear. I have run it open flow (20GPM) for two weeks and at the suggestion of a well service professional ran it with a choke at 10GPM for two hours and then rest for 30 min., for two weeks. It is very cloudy (can't see through it in a wine glass) after it is pumped for five minutes and then begins to clear after about 10 min. The well is 260' deep with the pump set at 220'. Static level is 180'. the driller thinks it is veins of shale running through the sand. He is going to drill me another well close to a neighbor's well that has great water at 285'. I tried a 1 micron whole house filter to see if it would have any effect. It did not. If I encounter the same problem with the new well, I think I'm stuck. Has anyone had recent experience with the Pentair Freshpoint filter? It's expensive and would not be much fun gagging down the cost if it did not clear the turbidity. Is there a way to test to see what I would have to filter down to to get results without purchasing the unit? I would appreciate any feedback.
    Well driller,pump repair. and septic installer Waterwelldude's Avatar
    Feb 2009
    Texas
    What part of Texas is this? If it is a well set in sand, it should not have any shale in the sand.
    The shale and sand should not in the same layer.
    "I shall never surrender or retreat" -Col. William Travis
    Feb 2012
    texas
    I'm in Grayson county which is north Texas. It is in sand. They hit sand after going through shale at 242'. We are pumping from a zone 16' thick. I watched them complete the gravel pack but did not see the bentonite go in. Thanks for the reply.
  1. where to buy overhaul kit for pentair, flowtec, craftsman ect.?
    By m151 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-23-2011, 03:54 PM
  2. Well Water Black sediment in my Whole house water filter (YUK}
    By JohnnyTuinals in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-30-2011, 08:20 AM
  3. Replies: 2
    Last Post: 04-09-2011, 05:21 PM
  4. Use Chlorine (Charcoal) filter in Whole House Sediment Filter Housing ??
    By kstuart in forum Plumbing Forum Discussion & Blog
    Last Post: 03-03-2011, 02:04 PM
  5. Pentek FreshPoint U440
    By cwall21 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-24-2009, 06:04 PM
