Thread: what does setting the Grain per gallons acually do when changed to different setting
    Default what does setting the Grain per gallons acually do when changed to different setting
    Hello all,
    I was wondering what moving the Grains per gallon dial on some water softeners actually does.
    Does it some how tell the valve how much salt to regen with??
    When it is switched to other settings how does it affect things?
    Also I have a Nozzle 0.042 what is it purpose?? Is it to meter the brine??
    Thanks Paul
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    When you change the GPG setting it will cause the unit to regen sooner or later. If you raise the setting, the system will regen sooner and if you lower it than later. I would advise you to find out what the hardness of the incoming water is and set the unit to about 2-3 grains above. The .042 is the rate of brine draw. It does not meter the brine flow.
    Feb 2011
    NW Ontario, Canada
    The softener only knows what you tell it and what it measures as gallons of water consumed and then calculates based on that. It won't know if you are lying or truthful.
    If you tell it the water is not as hard, it will regen later. If you tell it that it's harder than it is, it will regen sooner. If there is a long slow consuption, the meter might not measure it, skewing the results.
    The nozzle size roughly controls rate of flow. It's not exact as it's subject to the pressure and other factors. It need not be exact so is not field adjustable.
  1. Setting tub
    By lw211 in forum Shower & bathtub Forum & Blog
    Last Post: 04-16-2013, 12:47 PM
  2. Which A/C setting is more efficient?
    By Squ1rrel in forum HVAC Heating & Cooling
    Last Post: 07-05-2008, 09:07 AM
  3. Setting tub in mud
    By M3 in forum Shower & bathtub Forum & Blog
    Last Post: 04-02-2008, 09:06 AM
  4. Setting a tub.
    By pitteach in forum Shower & bathtub Forum & Blog
    Last Post: 02-23-2008, 09:17 AM
  5. help trap setting
    By daveydo in forum Shower & bathtub Forum & Blog
    Last Post: 11-07-2004, 04:31 PM
