Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: plastic push pull water valve problem
    DIY Junior Member rosieniko's Avatar
    Feb 2012
    charleston, sc
    Default plastic push pull water valve problem
    Plastic push pull water valves under residential sinks installed in 2000. Starting this month, the valves (mostly hot water but sometimes cold water) in most used sinks (master bath sink and kitchen sink) will "pop out" in shutoff position for no reason. Push them back in and they may work fine for a week of two and then one or two of them will pop out again. There are no leaks and this is not caused by any interference on our part. Any answers to why before I think about replacing them to avoid a potential leak (if they are acting up this way, I would assume the next step could be leaks).
    Dec 2009
    northfork, california
    The ones I saw were also push onto the pipe sharkbite type. You could try some tape on them or a HD rubber band, but a full on replacement would be a good project. They might not leak but rather blow apart. Better check your water pressure also.
    These are CRAP valves. Replace them now and be done with them. Most guys prefer the newer 1/4 turn style shutoff valves, but even the older types that require several turns would be better.
    Feb 2012
    charleston, sc
    Quote Originally Posted by ballvalve View Post
    Thank you for your answer. To my knowledge, and I did check with our local water authority, there are no problems with water pressure variations that could be causing any of this problem. Have you any evidence or experience with these valves actually blowing apart? I intend to replace them--just seems something is wrong and waiting for leaks or major problems does not make any sense. In the interim could taping them in the open position actually exacerbate a "blow out"?
    In my opinion, those valves are "garbage" the day they are installed and just get worse as time passes. They were used by "plumbers" who wanted to do the job as cheaply and fast as possible.
    Some of those valves had an integrated supply line to the faucet. They were very quick (and cheap) to install. Their gripper teeth may scratch the pipe enough when removing that a compression valve may have problems, then again, maybe not. If there's enough stubout, you might be able to cut the scratched/gouged part off. Don't know if they're removeable like the Sharkbite fittings (those work by pushing on the collar, which retracts the teeth so it can be removed).
    Most plumbers prefer compression valves over soldered, but either will be a great improvement over what you have. Sharkbites may or may not be reliable over the long haul. I would opt for the compression because they are quick and easy to install plus they have proven long term reliability.
    In the Trades liquidplumber's Avatar
    Feb 2012
    Gastonia NC
    I dont know a single plumber who even uses compression, much less prefers them .. Not trying to be argumentative, I'm just saying. IMHO If you CAN solder then you SHOULD solder.
    Agreed with everyone who says those shutoffs are crap. Around here we find those only in mobile homes or in the bottom of the barrel tract builder houses.
    Plumber jimbo's Avatar
    Quote Originally Posted by liquidplumber View Post
    You would be hard pressed to find a soldered angle stop around San Diego. They were never used by any major builder, and plumbers of every ilk....from handyman to the 50 truck guys, use compression stops all day long.
    Feb 2012
    Gastonia NC
    You would be hard pressed to find a soldered angle stop around San Diego. They were never used in by any major builder, and plumbers of every ilk....from handyman to the 50 truck guys,
    You mean your area is loaded with those cheap plastic push pull things?.. Here we have mostly a mix of directly crimped pex stops or soldered stops. In all my construction I preferred to use copper stubouts and solder on stops and do pex conversion in the wall. it looks better and provides more ridged support for the stop.
    Our local supply house tried for awhile to push those crappy stops on us but no plumbers around here were willing to take the risk on such cheap stuff.
    Feb 2012
    charleston, sc
    Outside of the fact that these plastic push pull valves are garbage and cheap, is there a specific reason why they would occasionally "pop out" and close the water line?
    Feb 2012
    Gastonia NC
    Quote Originally Posted by rosieniko View Post
    NO. theres no specific reason, heres several possibilities, off the top of my head.. Over pressure.. Ya got a PRV? is it working? is it adjusted properly?.. Have ya got a bladder tank? is it working properly? any possibility that water heater set or stuck way high? Maybe these valves are imitating hammer arrestors when some other water valve closes quickly??
    Maybe..... now I know this might sound crazy, the valve itself is worn out, defective, broken?
    And yes, it could be that its just cheap crap to begin with. You can check all that stuff I mentioned just to be sure none of those things are issues, and if all that stuff is ok You can live with it, or change em out, they arent repairable.
    The guts are a piston that gets pushed into a hole to close off the water flow. It's (I think) concentric, so if the friction that's holding in in the closed position is decreased (say a worn o-ring, or wear), line pressure can push it back out. It's a poor design.
    I've heard that some shower valves that used push/pull to turn on/off had the same problem if they were greased up too much...not enough tension to hold them in the off position, and they'd mysteriously turn on by themselves. WHen they get old, the mineral deposits often made them really hard to turn on or off, but when new...
    Homeowner
    Jan 2010
    Alabama
    Sure there is......water hammer. Water hammer can spike several hundred pounds of pressure when fast closing valve turns off. Such as washing machines,ice makers, Hose faucet with a sprayer attached and released quickly.......ballvalves that are quickly shut by hand.....etc etc.
    quote; I dont know a single plumber who even uses compression, much less prefers them .. Not trying to be argumentative, I'm just saying. IMHO If you CAN solder then you SHOULD solder.
    You must not know many plumbers or they are all union members who prefer to do things the "slow way" so they get paid more for the job. I have been using compression angle valves for the past 50 years, and have only used soldered ones a couple of times. They are NOT the slide on plastic ones, however. Since the valves close by pulling the handle out, the water pressure is ALWAYS trying to close them and if the mechanism becomes "loose" enough it will happen.
  1. Older Moen Push-Pull?
    By vavrousek in forum Shower & bathtub Forum & Blog
    Last Post: 08-25-2008, 07:02 AM
  2. Plastic Push Pull Valve
    By augieone in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-24-2008, 09:47 AM
  3. American-Standard push/pull tub and shower valve
    By paljoey in forum Shower & bathtub Forum & Blog
    Last Post: 10-01-2007, 05:30 AM
  4. Push-Pull Bathtub Stopper
    By whitpet in forum Shower & bathtub Forum & Blog
    Last Post: 06-26-2007, 02:15 PM
  5. Push/Pull drain removal
    By TripleE711 in forum Shower & bathtub Forum & Blog
    Last Post: 09-22-2006, 08:28 AM
