Results 1 to 6 of 6
Thread: Need major help with Delta 3 way diverter and 3 way cartridge
    DIY Junior Member Spunger1's Avatar
    Sep 2011
    Santa Barbara,CA
    Default Need major help with Delta 3 way diverter and 3 way cartridge
    Hey guys,
    I have a Delta 3 way shower diverter and the cartridge that goes with it. I just ran into a HUGE problem and it's not funny!!!
    Our bathroom is almost done from a remodel, so I went ahead and figured I'd install the cartridges. While I think the hot/cold are plumed right (I have no way of knowing at this point, a contractor did all the work) I figured I could do the diverter as that seemed easier. While reading the instructions to it over and over it said that the right port had to be blocked out and capped on the 3 way diverter. Problem arises. The contractor plugged the LEFT side instead. So I'm sitting thinking I'll have a shower, but no pressure will split between the handheld and the shower OR just the hand held. That was our whole point of going with 2 shower heads. To have one or the other on or both at the same time.
    Is there an easy solution to basically turn the valve 180 degrees so I don't have to rip open the back side drywall and remove the cap from the left side and move it to the right along with re-piping whatever shower head is on the right to left?
    I am so mad at this point I am not sure what to do. I tried taking apart the valve but it doesn't look like it's something I'm able to do as far as rotating the insides 180 degrees for it to function properly. I am just lost with this, this is the remodel from hell with all the problems.
    Normally, it would not make any difference whether the left or right port was capped, although most manufacturers do not recommend capping any of them but rather piping an "unused" port to connect with one of the other ones. It is a functional thing so you cannot select the capped port to shut off the shower's flow without turning the main valve off, thus creating a cross connection. I have not used that diverter so I am not sure how the cartridge works.
    Homeowner
    Jan 2010
    Alabama
    If you have this valve,you can cap off the left or right outlet but the top must be used.
    http://www.deltafaucet.com/customers...0#flashWrapper
    Sep 2011
    Santa Barbara,CA
    This is the valve that is used
    I am using it with this cartridge
    http://www.deltafaucet.com/bath/details/t11853.html
    In both sets of instructions it states plugging or capping the RIGHT side for using it in a 3 way diverter. Unfortunately my contractor like said plugged the LEFT side. I was trying to figure a way to reverse the valve or change it but it doesn't look like it.
    Am I screwed or might it work the way it is?
    As a last resort, just use the 6-function cartridge. All that should happen is that some positions will not have a function.
    DIY Junior Member smoken's Avatar
    Feb 2013
    Southeast
    Hi hj, I am in process on doing what you recommended in this thread. But, HOW DO YOU PULL THE OLD 3-function cartridge out of the valve body?
  1. Delta cartridge problems
    By vistaman in forum Shower & bathtub Forum & Blog
    Last Post: 10-15-2012, 05:24 PM
  2. Delta Select Cartridge or System ID HELP!!!
    By Bartman79 in forum Shower & bathtub Forum & Blog
    Last Post: 05-09-2011, 05:55 PM
  3. delta diverter
    By larryf in forum Shower & bathtub Forum & Blog
    Last Post: 01-09-2011, 12:51 PM
  4. cartridge for Delta R10000-UNWS valve
    By Joe Mc in forum Plumbing Forum Discussion & Blog
    Last Post: 06-30-2008, 04:45 PM
  5. Delta Shower Diverter
    By mynewacct in forum Shower & bathtub Forum & Blog
    Last Post: 09-30-2006, 06:49 AM
