When you change the GPG setting it will cause the unit to regen sooner or later. If you raise the setting, the system will regen sooner and if you lower it than later. I would advise you to find out what the hardness of the incoming water is and set the unit to about 2-3 grains above. The .042 is the rate of brine draw. It does not meter the brine flow.
