Thread: Old Toilet problems
    DIY Junior Member fredru's Avatar
    Feb 2012
    louisiana
    Default Old Toilet problems
    I have an American Standard toilet from 1985. Inside the tank it reads 4083 and M-3A. I have replaced the valve and flapper assembly 3 times in about 20 yrs. I last replaced the flapper kit less than a year ago. Eventually, these assemblies become unreliable and the toilet begins to run after every 2 or 3 flushes. Sometimes the chain attached to the flapper gets kinked and other times the metal flush handle itself just catches. Jiggling the handle will correct either problem but I don't always know it's running until sometime later.
    Is there a flapper kit you can recommend that is somewhat trouble free?
    I would think a real plumbing supply house would be able to provide decent innards. You will still have an old water hog toilet, but it still should work as well as it ever did. Before I replaced my master bath toilet with a Toto, I had an AS of approximately the same vintage as yours, and it actually worked very well for over 20 years.
    It appears that you need a new handle, not a new flapper. If it uses a standard flapper, and not a tilt-flush unit, then I ALWAYS use the Korky flapper.
  1. New toilet problems
    By Eva Shanley in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-02-2011, 11:13 AM
  2. toilet problems
    By homeowner25 in forum Toilet Forum discussions
    Last Post: 01-07-2010, 06:50 PM
  3. Toilet Problems
    By virtuo in forum Toilet Forum discussions
    Last Post: 11-07-2009, 03:42 PM
  4. Toilet Problems, Please Help
    By fsupilam in forum Toilet Forum discussions
    Last Post: 05-11-2005, 12:37 PM
  5. a toilet with 2 problems
    By jacobalfredo in forum Toilet Forum discussions
    Last Post: 09-28-2004, 03:57 PM
