Thread: In the ball park?
    DIY Junior Member PHONEMAN's Avatar
    Feb 2012
    LAND O LAKES , FL
    Default In the ball park?
    Im really new at this , so Ive got a 85 gallon tank , its a regular tank no bag inside of it, just a straight
    85 gallon, Pro Sourse tank, 1 hp jet pump. Setting are 30/60 . I get 18 gallons of water before
    pump turns back on, Takes about a minute or so to shut off after it comes on. Im I in the ball park as far as
    amount of water before pump comes back on?
    Ive got a deal that goes into the side of the tank, about 15 or so inches above bottom of tank
    not sure if it lets air in or lets air out or maybe both, it has a copper line that goes to the
    suction side before it gets to the pump.
    Charles
    Moderator valveman's Avatar
    Mar 2006
    With the perfect amount of air in the tank and a 30/60 pressure switch setting, you should be getting about 35 gallons draw down from that size tank. That little copper tube is part of your air maker system. And depending on how much air charge it keeps in the tank, determines how many gallons you get out before the pump starts. 18 is really not too bad.
    Feb 2011
    NW Ontario, Canada
    35 gallons is probably overly optimistic.
    http://www.nationaldriller.com/Artic...00f932a8c0____
    Mar 2006
    "Example 5
    This shows how the drawdown changes if we widened the differential between the cut-in and cut-out pressures from 30/50 to 30/60.
    Drawdown = (28 + 14.7) / (30 + 14.7) – (28 + 14.7) / (60 + 14.7) x 85
    Drawdown = 38.4 x 85 = 32.6 gallons."
    Sorry missed it by a little. But I used this... http://cyclestopvalves.com/runtime_app.php
  1. Pinnacle Peak Trail at Mount Rainier National Park
    Last Post: 09-28-2011, 12:37 PM
  2. Replies: 1
    Last Post: 06-08-2011, 05:24 PM
  3. Replies: 3
    Last Post: 02-15-2011, 06:05 AM
  4. You cannot park that there
    By Ian Gills in forum Ian's Corner
    Last Post: 11-29-2010, 12:23 PM
  5. Point Defiance Park, Tacoma
    Last Post: 06-08-2009, 08:09 PM
