Results 1 to 8 of 8
Thread: basement shower drain
    DIY Junior Member bdbieck's Avatar
    Feb 2012
    Trumbull, NE
    Default basement shower drain
    Our shower was put in in 1978 by my grandfather who was a plumber by trade. He installed a 36x36 durastall shower. We HAVE to replace this shower after 34 years. My question, the shower drain is 18" center, I want to replace the shower with a 36x48 tile shower but my husband says there is no way we can move the drain. Is there a way to do this without moving the drain?
    Homeowner
    Jan 2010
    Alabama
    You sure can. Your drain will not be centered as you know but it will work fine.
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by bdbieck View Post
    We often install a custom linear drain that can be installed over any plumbing location. I have them made up to 60" with all code approvals.
    Some of the other suppliers of linear drains sell "Off Set" drains.
    Many of the shower kits from Schluter, Noble Company and AKW can be added to or have product removed to work.
    There are a lot of ways of upgrading the style and look of your shower without busting up to much concrete.
    JW
    Jan 2008
    You should also consider that moving a drain a couple of feet should be no harder that building a proper tile shower. If you can do the shower, you can do the drain.
    Homeowner
    Jan 2010
    Alabama
    A couple feet???? Its only 6" off now. If the owners do not care about it being 6" off,thats all that matters.
    Jan 2008
    Quote Originally Posted by Hackney plumbing View Post
    I think you missed the point.
    A mud pan with tile can have the drain most anywhere. You just slope the pan to the drain.
    If you need to move a drain in concrete, it just takes a sledge hammer to break out a bit of concrete and the drain can be relocated.
    Depending on the type of shower you want to install (not the size, but referring to the type of construction), you'd probably have to change the type of drain that is there as well. This might require you to break up some concrete. Then, depending on the type of drain lines, if they are metal, sometimes it's a good idea to replace them anyway. While CI can last a very long time, it might not, and while what you have lasted over 30-years, I'm guessing you'd like the new one to last at least as long...so, depending on what's there, you want to make sure the 'infrastructure' is good to last as well as the new stuff.
    Most pre-cast/pre-made pans don't offer the option of placing the drain where ever you want it...you move the drain to where it's needed. A custom, tiled shower pan can have it anywhere, but centered (or end) works best. Yours isn't all that far off, so would still function fine, if (and that's a big if) done right. Lots of ways to build a shower, lots of ways to mess up. It's good you're trying to do some research...keep going.
  1. basement shower drain
    By DanAK in forum Shower & bathtub Forum & Blog
    Last Post: 09-22-2011, 06:32 AM
  2. old shower drain in basement
    By bowtech777 in forum Shower & bathtub Forum & Blog
    Last Post: 12-11-2009, 12:15 AM
  3. Basement shower drain help...
    By jfls45 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2009, 08:59 PM
  4. Shower drain attach to cast iron drain in basement
    By ken61282 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-13-2007, 06:10 PM
  5. shower drain in basement
    By photocray in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-28-2006, 11:19 AM
