Thread: Rough-in for bathroom fan?
    DIY Junior Member seattle_steve's Avatar
    Jan 2011
    Seattle, WA
    Default Rough-in for bathroom fan?
    I'm wiring an addition and I think I understand what the inspector will want to see as far as outlets, switches and regular light receptacles. But, how do I rough in the wiring for a bathroom fan? Now that I think about it, I guess the same question applies to recessed lighting. Do I install the fan (or recessed can) now and wire it up for the inspection? Or, do I just run the wire to the location where the fan/can will be? Or, do I put a temporary j-box there? Something else?
    Steve
    Typically you would have the can installed and the cable properly run to it. Just a bare cable hanging in the ceiling leaves too many questions.
    Nov 2009
    VA
    Install the recessed lights and fan (including wiring). They won't have any power at this point becuase the switch/outlets won't be connected yet. In addition, the bathroom fan should fall under the "mechanical rough-in" (ductwork, etc.), so the inspector will be able to sign-off on the rough electrical and mechanical at that time.
    The connections to recessed light and bathroom fans are really j-boxes. If you didn't install the lights/fan at this point, the inspector wouldn't know that they were being placed in a j-box (fixture) and it would look like you were going to leave live wiring hanging in the ceiling.
    Jan 2011
    Seattle, WA
    Make sense. Thanks, guys.
  1. Bathroom rough in
    By GeronimoDF in forum Plumbing Forum Discussion & Blog
    Last Post: 10-05-2010, 05:03 PM
  2. Should I rough-in for a bathroom?
    By kxmotox247 in forum Plumbing Forum Discussion & Blog
    Last Post: 05-27-2007, 06:58 PM
  3. bathroom rough in
    By lionhound in forum Plumbing Forum Discussion & Blog
    Last Post: 04-22-2007, 04:51 AM
  4. Bathroom rough in
    By wolfpack in forum Toilet Forum discussions
    Last Post: 01-30-2007, 07:40 AM
  5. another bathroom rough in
    By jakedvm in forum Remodel Forum & Blog
    Last Post: 01-09-2006, 09:21 AM
