Thread: Forced Air Heating
    In the Trades tingeyplumbing's Avatar
    Dec 2011
    Salt Lake City, Utah
    Default Forced Air Heating
    When it comes to central air conditioning and forced air heating you because we’ve discovered that many systems today are incorrectly installed because they are either undersized for their required use or just not properly installed the first time. A plumbing company can help you with that. So, what does forced air heating actually mean?
    A forced-air system is a system that uses air as its heat transfer medium. These kind of systems rely on ductwork, vents, and plenums for the air distribution and they are different from the actual heating and air conditioning systems. The air is carried by the return plenum from several large return grills (vents) to a central air handler for re-heating. All air handlers consist of an air filter, blower, heat exchanger/element/coil, and various controls. The temperature is whatever you set your thermostat to, and when the desired temperature is reached, the heat will shut off until the temperature drops down again. The type of equipment that heats the air represents the main difference between the types of forced air heating systems.
    When deciding the type of heating you are going to use for your home it's best to consider both advantages and disadvantages for each type of heating you are considering. For example, using a forced air heating systems has some advantages like it is simple and affordable. This simplicity helps keep the costs of forced air heat fairly low compared to radiant heating.
    Its simplicity helps keep costs fairly low compared to radiant heating. Also, it's an All-In-One-System which can be used to heat, cool and ventilate the home and it is energy efficient. But it has also its disadvantages like uneven heating and cooling, pollen and dust can be carrier inside and you can also hear the noise caused by the fan blowing the air thorough the events.
    Why did you post this comment in the Water Heater section?
    Aug 2009
    Midwest
    Probably because it is actually advertising spam for his/her business.
    Yeah, I looked a little closer, and that's what it is.
  1. Air Bubbles in Forced Hot Air Heating System
    By thesler001 in forum HVAC Heating & Cooling
    Last Post: 02-07-2009, 03:44 PM
  2. How to tile under a forced hot-water baseboard heating
    By jdbs3 in forum HVAC Heating & Cooling
    Last Post: 01-29-2008, 10:17 AM
  3. Pigtail, forced air heater
    By joeford in forum Electrical Forum discussion & Blog
    Last Post: 12-17-2007, 05:20 AM
  4. How to split one heating zone to multiple heating zones?
    By lmei007 in forum HVAC Heating & Cooling
    Last Post: 10-08-2007, 08:09 PM
  5. Forced Hot Water Heating System Relay Connection
    By skagrock in forum Plumbing Forum Discussion & Blog
    Last Post: 12-31-2004, 07:39 AM
