Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: disaster averted !
  1. #16
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    He also said he forgot to throw a blanket over the well head.
    In FL etc. the pressure tank and pressure switch is usually out in the yard at the well, where the switch nipple can freeze and usually will before other parts because it is a 1/4" nipple and doesn't take much time to freeze it compared to 3/4" or 1" water line. And the warmer water from the well can melt the ice in the lower end of the nipple as it flows past but that means the switch saw the pressure change and came on or he wouldn't have had water for his 10 minute shower.
    So I say ice blocked the nipple after the pump came on and the switch couldn't see the increased pressure to shut the pump off, which he did by flipping the breakers. Then the ice thawed as if it never happened.
    Or, ice in the water line going by the switch nipple blocks the end of the nipple and the switch doesn't see the pressure change to shut the pump off.
    Vacuum doesn't bulge a tank, it sucks the sides in, pressure bulges a tank.
    There is a 50/50 chance the pressure tank is in the garage. I understand the buldge would be from pressure, but what I'm thinking is the booster caused a vaccum which collasped the tank breaking the fibers and when the water came back on the tank "buldged". My question is, "Could the booster pump cause the vaccum"?
  2. #17
    OK, lets see....If the switch is in the garage and assuming it can't freeze, it is before the equipment, or should be.
    If the pressure tank and then the well pump and the booster pump were delivering water what was the cause of the booster pump causing this vacuum? Or, what shut off the water flow from the well to cause the booster to cause the vacuum?
    What made the well pump come on again after the booster pump created the vacuum?
  3. #18
    Nov 2010
    Ocala, Florida
    Good point. I believe the well line froze. With no water flow from the well, the pump caused a vaccum. I guess we will never know, but it is food for thought.
  4. #19
    Aug 2008
    Fairfield Co.,Connecticut
    You are violating plumbing code over 80 PSI. Install a low pressure cutout switch to prevent a vacuum situation. Good Catch.
  5. #20
    A vacuum doesn't cause a resin/mineral tank to swell and burst as the OP stated he saw happening..
  1. Need help with kitchen sink disaster.
    By distraught22 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-05-2011, 02:31 PM
  2. Gulf oil disaster
    By Ian Gills in forum Ian's Corner
    Last Post: 07-19-2010, 12:01 PM
  3. Expensive repair averted
    By Dmaxpower2 in forum Water Heater Forum, Tanks
    Last Post: 01-01-2010, 06:55 AM
  4. shallow well disaster?!?
    By vic_loven in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-24-2007, 06:22 AM
  5. How to prepare for disaster
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-05-2005, 07:32 PM
