Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: Delta shower valve repair
    DIY Junior Member sbslider's Avatar
    Mar 2011
    so cal
    Default Delta shower valve repair
    I am attempting to fix my leaking Delta shower valve. It is a single control type, see the attached picture. I started yesterday trying to disassemble it to replace the springs, seals, ball etc. I know that if I try to force it off that I will break three copper pipes behind the valve. I have been attempting to help my cause by applying my home grown liquid wrench (ATF and acetone 50/50) to the threads, and heating it a bit with a hair dryer and a plumbing torch. So far, 1 day in no luck. I am considering attempting to dremmel off the dome piece and/or the cylindrical piece that covers the pipes, but thought I would look for recommendations here first. I would prefer to not replace the valve, but I do have access behind the shower in the wall of a closet if necessary. One thing that prevents me from just diving in and cutting the metal is the availability of replacement parts for those pieces. I have not looked terribly hard, but have not found them yet. I failed to ask about them yesterday when I bought replacement parts for the internals at the plumbing store, but I did ask about the plate behind the valve and they did not have that.
    Thanks, Matt
    Aug 2009
    South*East
    Quote Originally Posted by sbslider View Post
    Thanks, Matt
    Your on the right track. Use your dermmel tool to split then nut then open up the split by twisting a screwdriver in the cut you made. The new replacement nut have a hex on them to make them easier to remove.
    John
    Homeowner
    Jan 2010
    Alabama
    First loosen the plastic ring with the notches in it. Heat the nut with a torch,slow and do not get it really hot...just warm it up good. It should be hot enough you cant touch it for more than a split second. Now take some channel locks and out toward the end of the bonnet....where you loosened the plastic ring,try to apply more twisting force that gripping force. If you squeeze too hard you will egg the bonnet and it will not turn. You cant see this happening. Watch the bonnet as you try to turn.....if you feel your channel locks move and not slip but the bonnet does not move you know to stop immediately and get your dremel out. Remember to turn rather than squeeze.
    Be careful and not cut too deep with the dremel if you use it. As Johnjh201 said cut it part way through and use a screwdriver to twist and split the bonnet. Once you split it and open the split with a screwdriver it should unscrew.
    All the parts are available.
    Mar 2011
    so cal
    Many thanks Gents, now I have an excuse to get myself a dremel tool. I did already try loosening the plastic part inside, but I did not try twisting from there. I'll give that a try, thanks.
    Homeowner
    Jan 2010
    Alabama
    There is actually a tool made to fit the bonnet,it prevents you from squeezing it.
    Mar 2011
    so cal
    Any recommendations for where to get a replacement bonnet online? I'm not a huge fan of driving around town looking for a special part. I've already been to a few stores and not found it.
    Someone said that it comes with a new cartridge...would need to verify that.
    If you twist too much, you can damage the lines to the valve and unless you're quite skilled, that may require replacing the valve itself rather than just the cartridge. A hacksaw could start to split the bonnet - you don't want to damage the threads of the body, though.
    Homeowner
    Jan 2010
    Alabama
    That faucet doesn't take a cartridge. It takes two seats,two springs,ball,cam packing,bonnet with adjustment ring.
    Take your pick!!!! Good luck and let us know how it goes. I suggest getting a total rebuilt kit. You have a Delta 600
    http://www.google.com/products/catal...d=0CE4Q8wIwAg#
    Mar 2011
    so cal
    turns out I don't have a delta 600, mine has a round handle and the bonnet nut screws on at the widest part, not the narrowest as shown in the part posted above. I'll figure this out yet.
    Aug 2009
    South*East
    That is the new replacement nut for the faucet you have. It will also fit there kitchen faucet.
    John
    Mar 2011
    so cal
    Copy, I guess they don't sell the part I have now.
    Homeowner
    Jan 2010
    Alabama
    You have a Delta 600. Yours is the acrylic(plastic) handle. A conversion ball is available to convert it to a metal handle. You need a complete trim and rebuild kit for a Delta 600.
    Homeowner
    Jan 2010
    Alabama
    Its been re-designed. It fits.
    Mar 2011
    so cal
    Yeah, after looking around more I concluded I just need to get the whole refurb kit. Thanks for following up, I appreciate it.
    Aug 2009
    Midwest
    It is much more fun to twist the whole thing off while trying to do a simple repair (been there)...I'm not a fan of these ugly Delta's that always seem to be siezed up when they are leaking somewhere. I've replaced half of them already.
  1. Old Style Delta tub and shower valve?
    By Firedrgn in forum Shower & bathtub Forum & Blog
    Last Post: 12-20-2010, 03:37 PM
  2. Repair leaking Delta shower valve
    By marvingreenberg in forum Shower & bathtub Forum & Blog
    Last Post: 03-14-2010, 05:53 PM
  3. Delta Shower valve install
    By Rich B in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2009, 07:39 AM
  4. Delta shower valve opinions
    By CharlieM in forum Shower & bathtub Forum & Blog
    Last Post: 05-21-2008, 09:29 PM
  5. Delta shower valve rough-in
    By northman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-15-2008, 11:40 AM
