Results 1 to 8 of 8
Thread: Ruud40 gallon Gas Hot Water Heater
    DIY Junior Member jarge40's Avatar
    Feb 2012
    pa
    Default Ruud40 gallon Gas Hot Water Heater
    Have a Ruud 40 gallon Gas Hot Water Heater that was installed 9/28/2008. Unit is still under warrenty (tank and component parts - both 6 year warrenty).
    For the past month (no previous problems), have been running out of hot water prematurally. Tried setting temp. to highest setting, still no change. Checked water temp. after letting tank reach temp., was initially 140 degrees. After a 10 minute shower, had to turn off cold water completely. This has been occuring for the past month.
    Gas pressure in house is ok.
    Homeowner
    Jan 2010
    Alabama
    1) Whats the temp of your incoming cold water?
    2) Whats the temp of the water your showering with?
    3) How many gallons per minute comes out of your showerhead while your showering?
    Use a 5 gal bucket to see how many gallons per minute your showerhead flows.
    Give me that info and I will tell you if the heater is operating within its limits. If not then we will go into the possible problems.
    Jan 2008
    If the heater is firing properly, it is very likely that the dip tube in the tank has failed. The dip tube directs the incoming cold water to the bottom of the tank.
    An unobtrusive way to prove it-
    If the dip tube has failed, your shower water will go cool, but if you take a sample out of the tank drain, it will be hot.
    Homeowner
    Jan 2010
    Alabama
    Your water heater should be able to deliver 70% of its tank volume within 20 degrees of the thermostat setting. For you this would mean the water heater should be able to deliver 28 gallons of water at a temp between 140 and 120 degrees.
    This certainly sounds like a dip tube failure. This was a big problem several years ago when a major supplier of dip tubes turned out faulty ones to a number of heater manufactures. While this problem has been rectified, it is still possible of a a dip tube to break. It is fairly easy to check and replace if necessary. The tube is flared on the the top end and just hangs in the cold water intake. Just remove the intake nipple and use your pinky finger to fish the tube out. If it is intact, it will be long enough to reach the bottom of the tank. If it's broke, just get a new one. You may need to trim the bottom end if it is too long. That's about all there is to checking and replacing a dip tube. Cheap too.
    Homeowner
    Jan 2010
    Alabama
    Dip tubes do not reach the bottom of the tank. Manufacturers have shortened the dip tubes lenght to HELP against thermal stacking.
    The best way to check a water heaters function is to perform a draw test. The heater should deliver 70% of its tank volume(in this case 28 gal) within 20 degrees of its thermostsat setting. In this case his water is 140 degrees so it should deliver 28 gal of water between 140-120 degrees.
    After the draw test if the heater fails then is the time to trouble shoot hands on.
    Feb 2005
    Cool slab home or crawl space??
    if you live on a slab home, odds are you might have a hot
    water slab leak.....
    this can resemble a dip tube problem...
    you can watch your meter to see if water is passing
    through the pipes....
    god created all men,
    Homeowner
    Jan 2010
    Alabama
    Quote Originally Posted by master plumber mark View Post
    A quick way to check to see if theres a leak on the hot side that matters is to turn the cold water off to the heater. wait a few minutes and then turn it back on. If there is a leak you will hear the heater pressure up.
  1. 66 to 50 Gallon Electric Water Heater Problem
    By Dunbar Plumbing in forum Electrical Forum discussion & Blog
    Last Post: 01-06-2012, 10:44 AM
  2. Instant on Water heater? or 80 gallon or both?
    By mikki499 in forum Remodel Forum & Blog
    Last Post: 01-26-2011, 05:17 AM
  3. 50 or 55 gallon water heater cost ??
    By ballvalve in forum Water Heater Forum, Tanks
    Last Post: 01-15-2011, 11:41 AM
  4. Pan for a water heater - regular 50 gallon tank
    By richard8 in forum Water Heater Forum, Tanks
    Last Post: 04-05-2010, 01:14 PM
  5. Nine Year Old 50 Gallon Water Heater
    By hudson in forum Water Heater Forum, Tanks
    Last Post: 04-12-2009, 05:44 PM
