Results 1 to 4 of 4
Thread: Skirted TOTO how to change seat
    DIY Junior Member AgentK's Avatar
    Feb 2012
    New York
    Default Skirted TOTO how to change seat
    In an earlier thread http://www.terrylove.com/forums/arch...p/t-29151.html I learned that my Bemis seat was installed incorrectly, using the plastic bolts supplied with the seat, rather than the proper Toto plugs If I remove the bolts from above, the nuts will fall inside the skirt. Is there any potential harm in that, or can I just "let the nuts fall where they may?". I will install the new seat with the proper TOTO anchors, of course.
    Aug 2009
    South*East
    There is nothing it could hurt. But you may have a problem removing the existing bolts with no way to hold back on the nut. You may be able to loosen them enough to be able to cut them off and let the remainder drop. They'll be waiting for you when you some day have to pull the toilet.
    John
    Feb 2012
    New York
    Thanks. By lifting up the seat as I loosen the bolts, they seem to hold by friction underneath. Good
    suggestion to cut them if I can only get part
    way.
    If you needed to get underneath, it's a simple matter of;
    Turn off and disconnect water supply,
    Aquia, remove the two side screws and lift off.
    Other skirted bowls, remove the velcro'ed panels, remove the nuts and washers and lift off.
  1. Will a Toto skirted fit here?
    By CarlH in forum Toilet Forum discussions
    Last Post: 12-22-2008, 10:10 AM
  2. Replacing toilet seat on skirted Toto
    By berkeley99 in forum Toilet Forum discussions
    Last Post: 03-09-2008, 06:02 PM
  3. Best Skirted Toto Toilet
    By momand3kids in forum Toilet Forum discussions
    Last Post: 03-13-2007, 07:11 PM
  4. Kohler One-Piece Toilet - Seat change
    By Antony Francis in forum Toilet Forum discussions
    Last Post: 12-10-2006, 06:35 AM
  5. toto skirted toilet rough in
    By eagleslawyer in forum Plumbing Forum Discussion & Blog
    Last Post: 10-06-2005, 05:40 PM
