Results 1 to 6 of 6
Thread: EPS15/99 Electronic Pressure Switch
    DIY Junior Member Dean Erger's Avatar
    Feb 2012
    Texas
    Default EPS15/99 Electronic Pressure Switch
    Does the EPS15/99 remember its settings after a power loss?
    Feb 2011
    NW Ontario, Canada
    Yes it does. In fact, power cycling it is one way to reset it should it trip off from loss of pressure.
    Dec 2009
    northfork, california
    Since I have a large bin of fine digital cameras, remote controls, and dvd players, nothing gives more pleasure than that beautiful old switch with screws and hinges and terminals that I can see and touch.
    I sure dont have anything digital 30 years old in the house. OK the first transistor radios still work, bu tthat was pre chip.
    Feb 2011
    NW Ontario, Canada
    My Square D didn't last 10 years and the non-adjustable low pressure cutoff was a PITA.
    Moderator valveman's Avatar
    Mar 2006
    A lot of people think a pressure transducer will last longer than a bellows or diaphragm in a mechanical pressure switch. I think it has a lot to do with number of cycles and mineral buildup. Although I still have an old video camera that winds up, uses film, and has no electronics, it doesn’t compare in performance to even the oldest electronic video tape camera. The electronics in my old VHS camera still work, I just can’t get tapes anymore.
    Dec 2009
    The 8mm video cameras were the most amazing combination of mechanics and electronics, all ready to take a dump in a moment. I have 2 sonys that stopped working. Found a website on just how to whack it againt a table or hit it with a mallet - and about 1000 posts saying it works, including the techs that worked on them - they did it and charged 100$.
    I found the safer way to touch a little spring and cog with a pencil to make it work another 4 hours. In a pinch, A good slap does work. My Kodak Retina3c from 1956 still takes better pictures, and except for the bellows, will last forever.
    Anything run by a chip can be programmed to die right on time to keep the company profit up. Unless you are an electro-nerd with endless free time, we have lost control over most devices in our house.
    We have acompany here deep in the woods that makes NASA pressure transducers. Those I could trust. The ones from back alley wongdong-whoa-to you LLC, are sabotage.
  1. Low pressure, pump stays on - tank, pressure switch? Replace all?
    By applebach in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-17-2011, 04:51 AM
  2. Just installed a new Electronic Sump Switch
    By jackofalltradesman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-27-2009, 07:05 PM
  3. Super High pressure, but pressure switch appears to work properly
    By yergnov in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-03-2009, 05:14 AM
  4. Replies: 1
    Last Post: 05-14-2008, 10:13 AM
  5. 2 Houses, 2 Pressure Tanks, 1 pump, 1 controller, 1 pressure switch pro help needed!
    By betaman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-05-2008, 05:07 AM
