Thread: Pressure tank distance from well pump
    DIY Junior Member w4mjr's Avatar
    Feb 2012
    Middle Tennessee
    Default Pressure tank distance from well pump
    I have a question about the distance of putting my pressure tank from the well. My well is 65 feet deep. I would like to my pressure tank and pressure switch in the corner of my shop that is 160 feet away from the top of well casing which would make the total length 225 feet to the bottom of well. Would that work ok or do I need to place the tank at the top of well casing but then I would have to make a small well house for the pressure tank only and I didn't want to do that. I read where some people place the tank under the house crawlspace of there house which is kinda the same setup. My plans are 3/4 hp subm pump with 20 gal pressure tank. Water is used for outside only.
    Feb 2011
    NW Ontario, Canada
    Put the tank where you want. In the case of a 600 foot deep well, the tank would be further away than that.
    Dec 2009
    northfork, california
    I have a tank 1000 feet from the well. Its the switch you want near the tank.
    Feb 2012
    Middle Tennessee
    Ok thanks. Just what I needed to know. I guess where I read on some of Lowes pumps the lift is 150 feet and I was taking it as the total pump distance. That must be something else.
  1. Distance between pressure tank and pressure switch
    By JAF in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-06-2011, 08:18 AM
  2. Should downhill distance be considered for head pressure of sump pump discharge ?
    By aswetich in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-04-2010, 06:29 PM
  3. Pump to tank distance ?
    By 42skidoo in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-29-2009, 07:17 PM
  4. shallow well head to pump/tank distance
    By rreynaert in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-26-2009, 06:49 AM
  5. Well is long distance from pressure tank -- help?
    By dguest in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-24-2007, 06:56 AM
