Thread: tk Jr. runs only with cover off
    DIY Junior Member howgag's Avatar
    Feb 2012
    Ontario
    Default tk Jr. runs only with cover off
    My takagi Tk jr. will only run with the cover loose or off. IT's 6 years old & worked fine until I removed the cover to change an "O" ring in the water control valve. If I try to run it with the cover on it trips out. Any ideas or solutions appreciated. thnx. runs fine with cover off.
    Jan 2009
    Do you have a remote, so you can read the error code? "Trips out" as a symptom description doesn't say much, but the self-diagnostic error codes can sometimes zoom right in.
    Takagi's telephone tech-help would be the next step, but have the manual in front of you when you call.
    Feb 2012
    Ontario
    Unit works fine with the cover off or bottom screws left off so the bottom hangs out letting it get more air. Tighten the screws, & it will trip the internal breaker & cover has to be removed to reset it, Don't get any codes. always worked fine till I had the cover off to replace the water control valve. any help greatly appreciated.
    Feb 2012
    Ontario
    THE unit seems to have cleared itself up, Works fine now with the cover secured.
  1. Man Hole Cover or Something
    By Pinchbug in forum Plumbing Forum Discussion & Blog
    Last Post: 07-08-2009, 12:40 PM
  2. Well pit cover ideas
    By Cmag56 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-13-2009, 10:08 AM
  3. Shallow jetpump with airtank, runs near empty before pump runs
    By educateme in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-23-2007, 06:28 AM
  4. PVC pipe cover
    By rwells0001 in forum Remodel Forum & Blog
    Last Post: 08-10-2006, 05:53 PM
  5. Overflow cover.
    By Roy Rowlett in forum Shower & bathtub Forum & Blog
    Last Post: 03-18-2006, 08:22 AM
