Thread: Top Fed Tank Toilet
    Homeowner
    Jan 2010
    Alabama
    Default Top Fed Tank Toilet
    This pic is of a top fed toilet with a fluidmaster installed. As you can see from the pic its been there working along time.
    I installed it over 15 years ago. Saved the lady 100.00 on a POS top fed ballcock.
    DIY Member tom12's Avatar
    Aug 2011
    California & UK
    Hackney, thank you for the pic. If it's been working in place for 15 years then fine. However, i cant quite grasp whats going on - is the drop from the valve feeding the fluidmaster?
    Homeowner
    Jan 2010
    Alabama
    Quote Originally Posted by tom12 View Post
    Yes,you are correct.
    Aug 2011
    California & UK
    Thanks again, it's an interesting set-up. I've never seen anything like that although i am familiar with ball-cocks and floats, mostly side-fed and occasionally bottom fed. Is the pic wc a typical, close couple wc, or a low level wc with a flush pipe? One other thing (thats probably pic perspective) the fluidmaster seems awfully low compared to the o/flow tube.
    As a matter of interest, whats the opinion on cutting an inch or two off an o/flow tube?
  1. Best toilet with tank for under $250.00?
    By mrthrills in forum Toilet Forum discussions
    Last Post: 11-02-2011, 10:28 AM
  2. Replace tank on older 1.6gpf Briggs toilet or buy new toilet?
    By brennok in forum Toilet Forum discussions
    Last Post: 03-05-2010, 06:57 AM
  3. Concealed tank toilet (in wall tank) Geberit / Duravit
    By celicnibo in forum Toilet Forum discussions
    Last Post: 10-05-2009, 09:35 PM
  4. Tank to toilet gasket with two holes on side to hold tank
    By xnaron in forum Toilet Forum discussions
    Last Post: 05-17-2009, 08:16 AM
  5. toilet tank
    By farrington in forum Toilet Forum discussions
    Last Post: 04-24-2006, 04:43 PM
