Thread: Booster Pump - Switch Chatter
    DIY Junior Member Dean Erger's Avatar
    Feb 2012
    Texas
    Default Booster Pump - Switch Chatter
    I have a water well system with a water storage tank. Water from the storage tank goes through a booster pump for pressure, then to a pressure tank (on a “T”) and on to my home. I’m planning to replace the booster pump with a Red Jacket 100SRJ shallow well jet pump.
    The installation manual for the pump states: “The pump must be within 4' of the tank to prevent switch chatter. There should be no filters or valves, other than a wide open gate valve, between the pump and tank. … Do not place valves or filters between the pump and tank, other than a fully open gate valve or “full port” ball valve. The most common ball valves are not full port! Most valves and filters will create excessive friction loss and cause “switch chatter.” http://completewatersystems.com/wp-c...SRJ_DRJIOM.pdf
    The manual isn’t clear. Are they talking about a pressure tank or a storage tank?
    My storage tank is very large (about 8 ft high by 6 ft dia), about 75 ft from the booster pump, and has a 2” ball valve at the bottom outlet of the tank. I’m not sure if the ball valve is full port, but I doubt it is. The Red Jacket pump suction is 1 ¼”.
    Will the Red Jacket pump work okay with my water storage tank 75 ft from the pump? If so, since the ball valve is 2” and the booster pump suction is only 1 ¼”, would I need to replace the 2” ball valve at the bottom of the water storage tank?
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by Dean Erger View Post
    They are talking about a pressure tank downstream of the pump. Ball valve is fine.
    Feb 2012
    Texas
    Thanks. I thought that they were referring to a pressure tank, but I wasn't sure.
  1. Pressure Switch for booster pump
    By Bob1000 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-28-2008, 05:17 PM
  2. pressure switch chatter at cut in
    By lofty in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-25-2007, 07:51 AM
  3. Pressure switch chatter
    By SeriousDIYer in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-17-2007, 12:57 PM
  4. Pressure Switch for booster pump
    Last Post: 03-17-2007, 02:00 AM
  5. Pump chatter/surge at pressure switch
    By jmdeng13 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-29-2006, 11:36 PM
