Results 1 to 9 of 9
Thread: Parallel Water Heaters - Want to Install Recirc Pump
    Default Parallel Water Heaters - Want to Install Recirc Pump
    Hi All,
    I'm new here. Hope you folks can help.
    I have finally tired of my wife complaining about waiting for hot water at the shower. I am looking at the Grundfos Recirc pump. I have a question:
    Since I have two water heaters running parallel will I need to install two pumps or just one pump where the two hot water out lines connect? I'm thinking one will work but I thought I would ask.
    Plumber Cass's Avatar
    First, in order for the circulating pump to work you need a return line so the water can circulate. Do you have a basement and is it finished.
    Feb 2005
    Talking pump install
    if you have two water heaters in parrell,
    you are going to have to install the return line
    into the cold inlet to the water heaters BEFORE it
    divides off to both units, and you will have to install
    a spring loaded check valve before this connection
    to keep the water from going back up the cold line..
    ps......you are opening a huge can of worms here because
    all you are realy doing is spoiling your wife, once she realizes
    that you are willing to go through all this trouble to please her
    it will never end...
    Default pump
    One pump in the common outlet pipe will do find. But you will need a "Comfort" control valve at each "far end" of the piping system.
    DIY Member jimmym's Avatar
    New York
    Quote Originally Posted by master plumber mark
    A wise man.
    Your name should be "master AND plumber mark".
    zma98,
    All you're doing is reinforcing the idea that her nagging gets her what she wants. Like giving in to those screaming kids in the grocery checkout line. If the dog takes a leak on the carpet, do you give it a bone?
    You can lead a horse to water, but cannot make it drink.
    But if it does, it'll expect you to lead it everywhere anytime it wants anything!
    Now, that said, do you want a project? If so, go ahead. Plumbing and building stuff is fun.
    Like my buddy Sean said to his daughter when she asked why we were working on our project in the garage. "Honey, a project is something Daddies do when they want to get away from the Mommies."
    Feb 2005
    Talking thats a good saying
    that is a very wise saying that you posted
    I will remember it
    another good saying...
    Never give a sucker an even break......
    because if you do, he will never learn aything from the experience
    of being someones chump..,
    and will just keep repeating the same mistake over and over agian.
    Mark, I like it, you can boil it down to this:
    One thing man never learns from history is,
    that man never learns from history.
    New York
    Sorry about the smart a** comments.
    I thought that you should put the water heaters in parallel. That way you are assured that one is not doing most of the work because of uneven flow.
    Thanks guys. Love the humor.
  1. Hot Water recirc, replacing pump need suggestions
    By rods in forum Water Heater Forum, Tanks
    Last Post: 03-29-2013, 02:57 PM
  2. 2 water heaters, series or parallel??
    By macingrace in forum Water Heater Forum, Tanks
    Last Post: 12-11-2012, 03:11 PM
  3. Water heaters piped in parallel
    By greekguy7 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-24-2007, 06:58 AM
  4. Hot water recirc pump
    By NaplesX5 in forum Remodel Forum & Blog
    Last Post: 08-04-2006, 10:04 AM
  5. hot water recirc pump
    By gfe76 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-04-2006, 07:19 AM
